P1000m5 Won't change gears
Choped5er
Choped5er
182
279
Union
I think I have code 67 blinking on my dash it's stuck in first gear and limited to less rpm than normal also. Can anyone tell me what may cause this? I havent seen anything about code 67 on here thanks
Reactions: Neohio and BWAF
Choped5er
Choped5er
182
279
Union
I finally figured out how to get to the PDF file for service manual. Found out it's something with the front VS sensor. Hopefully I can troubleshoot tomorrow before work
How’d this turn out? There’s several things that can cause this. When it happened to mine, it was a wire chewed in two by a rat under the seat, drivers side. :D
Reactions: Hittman and BWAF
Choped5er
Choped5er
182
279
Union
I actually haven't gotten time to get back to it! What wire was it and I'll look there first! It could be that no kidding because it sat for about 4 months and the i only rode about 2 hours before this happened
Reactions: BWAF
If you zoom in on this pic you’ll see the chewed off piece of wire laying there and it came off the plug on the far right. This is directly under the drivers seat.
072FE9C8 DD0A 4E3D 93F9 595B6290AE3A
Reactions: Choped5er and BWAF
