P1000 Wont start
JohnnyG
Ivanhoe,TX
2016 1000-5. So I have been trying to work on my sxs the last couple weeks. It was running fine (other than the clutch slippage) and then tried to start it and just turn over. I changed plugs and it would fire up for 10 seconds and die. I checked the fire and it's good. So I decided to drain the fuel since that's the next place to look. Drained and I believe there was water in the fuel. I hooked the fuel pump up out of the tank and no pumping. I tried the fuel level and was getting power to there but no pump. I decided to replace the fuel pump, and put it in and turn it on and no pump again. I am out of options, any suggestions? Not sure if it will give me a mild light with out it starting but it seems to be 13. I see that is the injector and those wires seem to be tight and not pulling out.
Neohio
Neohio
Beast of the East
21,761
93,350
Painesville Ohio
If you have a code 12 or 13, order the injector plugs from our forum store or Amazon.
Well known issue on 2016's, even some 17's and 18's.
Reactions: Mudwing
JohnnyG
Ivanhoe,TX
Apparently the fuel tank vent in the frame let water into the tank. So new fuel pump and I'm up and running . Thanks for the advice. I will probably order one to have when the problem arises.
Reactions: Mudwing
E
Ericthered
Eric The Red
271
522
Sparks, NV
NO, just extend the vent to top of cab. I did and have no issues. 2017 1000-3eps
