X4 fit in 13 ft garage in a toy hauler
ronleblanc
Luling, La
Has anyone tried to load a X4 into a toyhauler with a 13 ft garage? I know the specs say yes but it seems like it would be extremely tight. I want the talon but thinking rzr might eliminate loading headaches.
Yes, I have a 13’ garage. The Talon (stock) is 12’8”
I have a sliding glass door that I had to protect. Had to add to the etrack system, but it fits. The real test will be when I pull it to the Colorado ride later this month...
7A61282E DAA6 40E2 A798 66213B902F85
F6701BC7 F333 4456 A031 9765656928FE
7C5A2347 9CCF 4787 A9EA 0F891F388ECF
764A62F7 0419 4CC0 90FF 4E0D68A91152
ronleblanc
Luling, La
Thanks man. That makes me feel a lot better about putting an offer in on one.
You’re welcome....😊
Just make sure the brand toy hauler that you’re buying has actually a full 13’, I had a 10’ toyhauler before and the actual in the clear was 9’10”.
And remember that you can’t do any mods that will increase stock length....👍
Good luck.
Reactions: Remington
Dcaren
SoCal
  1. Talon X4
My hauler has a 14' garage and the fit is very tight. I doubt a 13' garage would work. Here is a screen grab from the security camera in my hauler. The front is 5" from the wall and the back is 1-2" from the door. Might barely fit in a 13' if you don't have any bumpers. I have the factory front and rear bumpers.
Untitled
Reactions: TimG
The stock length X4 absolutely fits in a true 13’ garage. I transport mine in a 13’ garage 2” front and back clearance...
Reactions: nitrotmann
nitrotmann
nitrotmann
65
177
  1. 1000 6 Crew
Mine fits in my 2018 fr stealth 29fq
Sent from my SM-N986U using Tapatalk
Reactions: Montecresto
PaulF
PaulF
1,462
4,814
Careful, a 13' garage isn't always 13'. I have a Momentum 381M and it does have a 13' garage (actually 13' 1") but mine has the patio enclosure and 3 Season doors and they take up about 8" so my 13' garage is now only 12' 5" and an X4 won't fit my 13" garage unless I remove the 3 season doors.
Correct, which is why I was careful to say if it’s a true 13’ garage a stock X4 will fit.
I had a 10’ garage and it was 9’8” in the clear....
bjniceguy
322
431
Iowa
may want to think about large wheel chalks mounted to e-Track so sure you stop. Then when get where going can just take out and use area. Also may work well in strapping over tire with e-track and chalk so stays where you want it. I am not near as tight as you guys, but I want it in a certain spot for load balance
Reactions: CID
If there was a way to have quick release to remove them while you’re camping, it would be a good idea. I have to put an area rug back there to cover the e-tracks as it is because of the trip hazard....
