X4 fit in 13 ft garage in a toy hauler
ronleblanc
0
Luling, La
Has anyone tried to load a X4 into a toyhauler with a 13 ft garage? I know the specs say yes but it seems like it would be extremely tight. I want the talon but thinking rzr might eliminate loading headaches.
Yes, I have a 13’ garage. The Talon (stock) is 12’8”
I have a sliding glass door that I had to protect. Had to add to the etrack system, but it fits. The real test will be when I pull it to the Colorado ride later this month...
7A61282E DAA6 40E2 A798 66213B902F85
F6701BC7 F333 4456 A031 9765656928FE
7C5A2347 9CCF 4787 A9EA 0F891F388ECF
764A62F7 0419 4CC0 90FF 4E0D68A91152
ronleblanc
0
Luling, La
Thanks man. That makes me feel a lot better about putting an offer in on one.
You’re welcome....😊
Just make sure the brand toy hauler that you’re buying has actually a full 13’, I had a 10’ toyhauler before and the actual in the clear was 9’10”.
And remember that you can’t do any mods that will increase stock length....👍
Good luck.
Reactions: Remington
Dcaren
SoCal
My hauler has a 14' garage and the fit is very tight. I doubt a 13' garage would work. Here is a screen grab from the security camera in my hauler. The front is 5" from the wall and the back is 1-2" from the door. Might barely fit in a 13' if you don't have any bumpers. I have the factory front and rear bumpers.
Untitled
Reactions: TimG
The stock length X4 absolutely fits in a true 13’ garage. I transport mine in a 13’ garage 2” front and back clearance...
Reactions: nitrotmann
nitrotmann
nitrotmann
52
150
  1. 1000 6 Crew
Mine fits in my 2018 fr stealth 29fq
Sent from my SM-N986U using Tapatalk
Reactions: Montecresto
PaulF
PaulF
1,462
4,810
Careful, a 13' garage isn't always 13'. I have a Momentum 381M and it does have a 13' garage (actually 13' 1") but mine has the patio enclosure and 3 Season doors and they take up about 8" so my 13' garage is now only 12' 5" and an X4 won't fit my 13" garage unless I remove the 3 season doors.
Correct, which is why I was careful to say if it’s a true 13’ garage a stock X4 will fit.
I had a 10’ garage and it was 9’8” in the clear....
bjniceguy
322
431
Iowa
may want to think about large wheel chalks mounted to e-Track so sure you stop. Then when get where going can just take out and use area. Also may work well in strapping over tire with e-track and chalk so stays where you want it. I am not near as tight as you guys, but I want it in a certain spot for load balance
Reactions: CID
If there was a way to have quick release to remove them while you’re camping, it would be a good idea. I have to put an area rug back there to cover the e-tracks as it is because of the trip hazard....
