P1000 Honda Auxiliary Fuse Box
NewHere2
NewHere2
Village Idiot In Training
41,440
342,276
High Plains of SD
I like to keep things looking stock. So I purchased the Honda Auxiliary Fuse Box and 4 illuminated Honda switches. To be installed in my 2022 1000-5 Deluxe.
Thought this would be an ideal time to do the dual battery install with isolator.
What a waste of good money and time. I don’t know who makes the fuse box for Honda, but the quality isn’t there.
I found 3 switch connectors that were loose and the wires pulled out of the pins. In addition, several of the pins were installed upside down and didn’t lock into the switch backs.
I followed the instructions to a “T”. Mounted everything according to the instructions provide by Honda. When I made the final assembly in my buggy ( following the instructions) the negative wire pulled out of the eye loop and shorted against the positive wire.
Examining the negative wire, just the heat shrink was holding the wire into the eye loop. It had never been crimped. Glad it happened while I was standing there rather than bouncing down the road.
No damage was done to the fuse box board or fuse box. Nothing that couldn’t be fixed. Just a pain in the ass.
I would not recommend this install to the average mechanically inclined person. It can be done better, quicker, and a lot cheaper using items sold in the club store.
Fighting thru the project, I got it done. I also install 4 of the extra large illuminated Honda switches. Several other switches, and a front and rear winch setup.
Almost forgot an 8” Under seat fan.
3C275E0B 5F78 4E09 B85B D234E3F1902A
10945F21 D453 410F A12D 83CD46957776
A11AE890 7F47 40D8 B39E B82D3BC16D90
80AFB9D2 3D1F 4A79 91B2 9553E7BDD223
BFB6E079 14E4 44C2 9548 DB172A5761B1
15269602 5617 423A AB49 4C5FD5BC6B15
Scoop
Scoop
5,125
20,258
  3. Talon R LV
Glad you got it all worked out. Just added a fan and heat shield myself before TO. It helps.
BTW: If you added *anything* to it, even if OEM, it's no longer "stock". I think you means you like to stick with OEM accessories. ;)
66,720
Yep.
I did a quick review last year on its lackings.
I also can't recomend it.
It has lots of potential but the issues outweighs its positives.
NewHere2
NewHere2
41,440
342,276
High Plains of SD
Yep.
@Hondasxs Yes Sir, I read your review before I purchased the Fuse Box. I had hoped, over a year later after your review, the problems would have been resolved. So I tried it.
Thank You Sir for all the items you sell in the store! It makes any install easier.
NewHere2
NewHere2
41,440
342,276
High Plains of SD
Do you have plans for the wiper circuit?
I have been wanting to use that line for switch backlighting.
I used the Wiper Circuit to power my under seat 8” fan. The fan draws more than any of my other accessories. Excluding the winch of course.
As I recall, the fan drew 2.4 amps at start and .56 amps running.
Works good.
23genemachine
0
My '23 700 has battery under the seat, I put Honda accessory fuse box under the hood. The leads they included were meant for other models with under hood battery, or dual batt set ups. Are guys running leads to original under seat battery to power this accessory box?
