Just Got My New Pioneer 700-4
SkyPup
151
14
Installed 50 feet of header wrap (2 - 25 foot wraps one on top of the other 25 feet each way) and cut down cab heat over 50% and quieted down engine considerably.
Heat20Wrap
63,529
Thanks. You just wrap it like tape?
Did you go all the way to the muffler?
Why you wrap it twice?
SkyPup
151
14
Yeah, I just wrapped it like you would some tape.
25 feet does not go all the way to the muffler but almost, did not bother with the muffler since it is so far back and I am getting a YOSHIMURA slip on to replace the Honda muffler, should have the slip-on to install this weekend.
I wrapped it twice to make sure that the heat was being trapped well, I guess you could get by with one 25 foot wrap, but I figured two wrap depth would be much better than just one.
SkyPup
151
14
It cuts down on the vibratory resonant engine noise noticeably.
SkyPup
151
14
So much so that most of what I hear now is the air intake rush through the snorkel into the air box.
SkyPup
151
14
Headshot 225 yards using ACOG TA02/FLIR T-70, DRT.
22520Yard20Coyote
63,529
Sky, Did you just wrap over the head pipe cover? Kinda looks like but I just want to make sure.
Thanks.
SkyPup
151
14
Yes, I did, to encase everything to keep the heat insulated inside...
63,529
Thanks.
Nice Coyote. I went hunting last week. see a few but too far to get a shot. Tried to call but they never came.
SkyPup
151
14
That is why they call it hunting!
It is very difficult to get them to commit, usually they just hang out out of range in the shadows, if they get a whiff of your scent you can kiss them goodbye....
SkyPup
151
14
Installed a beautiful Larson Electronic 27 Watt RED LED spot blaster and man is it totally professional first class all the way.
The Red LED Light knocks your socks off and I will be using this cruising around at night with the FLIR thermal on when not using 850nm NV IR LED lights!
I had another 2-Rigid Industries White 4" LEDs with four LEDs with a Rigid Industries Red Plastic Lens covering the white LEDs, it pretty much suxed as you were hard pressed to see 100 feet in the dark with the weak filtered red light.
The real RED LEDs are 10X better and blow the red lens covers away.
Larson20Red20Led20Front
Larson20Red20Led20On
SkyPup
151
14
Also installed the beautiful Yosh exhaust pipe today too, it is a very nice professionally made exhaust kit that includes the stainless steel pipe back to the header junction and the slip-on stainless steel muffler.
It has a nice quiet throaty sound on idle and cruising around but when you step on the throttle 1/2 or more it sends out some serious sound waves similiar to my KTM 690 Adventure bike, BRAPP!
It was an easy install and a very nice unit.
Yosh20Pipe20Parts
Yosh20Pipe20Side
Yosh20Pipe20Rear
SkyPup
151
14
Another pic of the Yosh can:
Yosh20Rear20Pipe
63,529
Looks nice. I did not expect you to go with something like this. I figured if anything you would go with a silencer.
So why the reverse?
So, you have full capabilities to ride in pitch black dark with that IR light. Right?
Dude.. you have the best Pioneer out there.
SkyPup
151
14
On idle and cruising it is a bit louder than stock but not obnoxious, step on the throttle hard and it is obnoxious though. It definitely is not stealth, that is for sure...
Here is what my 850nm IR headlamp looks through Night Vision Optics, i can see for over 1/2 mile with ZERO VISIBLE LIGHT!
Cattle20Pasture20Road20850nmB
That reflector out there in the cattle pasture is 1/2 mile out....
SkyPup
151
14
There is a welded on stainless steel screen spark suppressor insert in the end of the can that you can remove for absolute straight through exhaust. Plan on keeping that insert installed as without it, it is EXTREMELY LOUD as it breaks up the sound wave pulses to keep it from sounding like a straight pipe.
I measured with a decibel meter three feet from the straight through exhaust and it hit 105 db - this is NOT GOOD for your ear drums!
With the stock YOSH spark suppressor in its stock position, it measures 98 db at three feet.
Stock muffler exhaust was 88 db at three feet for comparison....
With two balled up 4"X4" stainless steel screen inserts crammed into the pipe and then installed the stock spark suppressor to keep everything from flying out, it measures 95 db at three feet. This is acceptable to me as idle is nice and throaty, cruising with no load is nice and throaty, and stepping on the gas is still pretty loud when you want max power and acceleration.
It does start, idle, and run magnificent! Probably another 5-6hp with K&N and Yosh pipe over stock setup!
Plus, when you turn it off -> there is no tingling of the header pipe cooling down. When you turn it off there is no sound at all, this is a nice improvement over the OEM stock pipe and heat shields tingling for five minutes during cool down. I did not put the OEM heat shields back on the header pipe, I just wrapped that with thermal header wrap to keep the heat radiation minimized and increase heat flow out the muffler.
SkyPup
151
14
Busted another one with my Browning Hi-Power this morning....
Hi20Power20Hog
