Marine Auxiliary Switch Panel with dual battery setup
fishin2Dmax
fishin2Dmax
186
32
No, there isn't any wiring instructions with the 8 switch panel. This type of installation requires basic wiring knowledge, however, the panel is pre-wired from the switches to the circuit breakers and internal switch lamps (saves a lot of time). All you need is a main 12 volt power source to the switch panel and then adding a wire from each switch to the accessory you wish to install. If you don't have a lot of accessories you need to power, then the OEM switch panel may be the best route for someone that doesn't have wiring experience.
