P700m4 RZR Shocks??
bagotaco
bagotaco
121
77
Here's a little better picture of the bracket. Without it the shock would not mount in the factory spot. It put the cv shafts in to much of a bind.
I think I'm going to change gears for now and go in a different direction. I need to fix my suspension geometry by removing the HL lift and I'll save my coins for a shock upgrade for the P1000. That would be money better spent IMO.
266,574
There ya go bump that bad boy up to FOX 3.0" internal bypass shocks and up the travel to 13" :p
scott
scott
1,212
1,354
lyman, South Carolina
I'm waiting to see what the 1000 shocks are like. If they are good i might just get them and put on my 700 if they fit. One guy on the facebook page used front can am comander shocks he said it added about 1.5" lift to front. Think it was 2011 year model.
Reactions: joeymt33
dieselmax
dieselmax
Thunder Bay Ontario Canada
i have the can am commander front shocks on my machine and did a 110km ride recently we had approx 1000lbs aboard and the front end never bottomed out once. i was able to drive quite abit faster than last yr when we did the same ride
I finally quit playing around and bought some rzr 900 rear shocks. Thank you guys for the info on this thread. Here is some pics. No CV binding at full droop and I've achieved lift for 28" tires with out rubbing.
06988f90de6466f696dc57745566943b
20c13df746a08dba374a874c82f7d72d
Reactions: bagotaco
bagotaco
bagotaco
121
77
Your goin to love how much better it rides
TimmyBoy84
TimmyBoy84
56
34
Southern California
Sweet! Good buy with some simple fabricated brackets. I caved and ordered the WE Monotubes all around and now just impatiently waiting for them :confused::mad::D
66,875
They are worth it. I love mine.
TimmyBoy84
TimmyBoy84
56
34
Southern California
20151024 163522
Mine have become a nightmare. Its taken over 2 weeks to get them and when they arrived they set the rears up wrong and forgot the spring spacers to clear the arms and axles in the rear :mad::mad::mad:. I called WE and spoke with a guy named Chris who helped me out and knew right away what the issue was and ill get the missing stuff today, as for the fronts they fell right in and look sweet!!! :D:D:D
Reactions: Tflynn
bagotaco
bagotaco
121
77
Update.... since I installed the fox podiums on the front off my 700 I found out that I need to install limiting straps. It extends to much and puts the axles in a bind
G
green02crew
158
54
Get some fox shocks from a commander!
Gabriel727
Gabriel727
22
Tampa bay area,fl
Where can i get better shocks for my 2016 honda pioneer 1000-5? That will hold the weight of the sxs wish is 3800lbs i belive
