Talon X Portals!
SuperATV
SuperATV
1,249
8,720
Madison, IN
www.superatv.com
Giphy
Honda Talon 1000X 4" Portal Gear Lift
Talon X 4" Portals
Honda talon x 4 seater 4 inch portal gear lift 2
Honda talon x 4 seater 4 inch portal gear lift 7
Honda talon x 4 seater 4 inch portal gear lift 5
6" Portals coming SOON!!
aauman88
aauman88
1,091
2,846
Ok 6” is perfect for the X4 and I believe the 4” would be perfect for the standard Talons. Awesome looking setups
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
Do these portals change the (Hub to Hub) front to rear track width difference?
DDDonkey
The portals are a straight drop down of 4 or 6 inches. They do widen the track by 8 inches overall front and rear but should not change the front to rear track except for the larger tire diameter.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I understand that.
However since new spindles/ knuckles are provided (and they are different front to rear) there’s potentially room to keep the added width to a minimum.
SuperATV
SuperATV
1,249
8,720
Madison, IN
www.superatv.com
I understand that.
Its an even 4" per side. The included hub brackets don't add anything to original width from your stock hubs. You'll just tack on another 4" per side, making you 8" wider over all. That can be manipulated with different wheel offsets, but the portals do have a limit to how far of an offset you can use.
Reactions: Sheetmetalfab
BigDogHall
Pickens
  1. Talon X4
Hey I just purchased 4 inch portals for my x4 live valve well it clear 35’s on 15’s
Reactions: SuperATV
