P700 Which Winch mount to use with the Denali plow
mpilihp
109
204
Maine
So I got a great deal on a used Denali standard plow and I see in the store for the Denali mount for a 700-4 it states it does not work with a WARN or KFI Winch mount.
What winch mounts have people successfully used with a Denali plow and how was it to install?
Thanks!
Phil
Brmcg324
Brmcg324
51
199
SW Ohio
I have a Denali 66-inch plow and a superwinch on my 500. No interferences, but I do not know about the issues with WARN or KFI winch mounts. I ordered a universal winch mount on amazon, worked OK for the superwinch, bought in 2020.
I read recommendations for these items on this forum, worked out great for me.
41BF0E8A C1FD 43E3 BFFD 7C0106872739A377199B 8203 43E5 9410 76EE2AF0752A79C9D070 0198 4CD8 A2A6 1D63FABDDF80
mpilihp
109
204
Maine
View attachment 323202View attachment 323203View attachment 323204
Hi thanks, I do think the front end of the 500 is different than the 700 so may not be apples to apples but thanks! ~ Phil
swsebek
swsebek
2,854
5,828
pa
I have the 72” Denali and I use the Moto alliance mount from there website
BC6A079F DCFE 408A B843 95C48F2F4D84
mpilihp
109
204
Maine
Hi I am ordering this plow mount, what I am asking about is what winch mount you used. Says about the MA11718 mount that it does not work with the WARN or KFI Winch mounts.
Thanks Phil
Reactions: swsebek
swsebek
swsebek
2,854
5,828
pa
Thanks Phil
I’m sorry I misread that.
Thanks Phil
sorry about that. I have to check, but I believe I am using the kFI mount. But things may have changed since 2014. I use a viper winch and love it.
swsebek
swsebek
2,854
5,828
pa
Ok after looking at my ride I do have the kFI mount. And there is no way I can see it even being close to interfering with the plow or plow mount
Reactions: Buggyman
63,893
I have been told this has been revised and may now fit.
Does the KFI moutn to the bottom bumper bolt?
Buggyman
Buggyman
34,449
294,432
ne. ohio
This is my KFI mount on 2014 700 with KFI plow mount but Denali mounts on bottom bumper bolt as well I think you should be ok
PXL 20220308 225601414
PXL 20220308 225546952
mpilihp
109
204
Maine
Hi guys thanks so looks like the KFI will work fine then. I do wish they mounted the winch higher but maybe its to prevent interference issues with the bars it mounts to.
THank You
Phil
Reactions: Buggyman
Buggyman
Buggyman
34,449
294,432
ne. ohio
THank You
Phil
hope it works out for you
mpilihp
109
204
Maine
So any thoughts on this one? it appears it mounts the winch higher up, doesnt look as rugged but I only intend to use the winch for plowing, the UTV is a tool for us for hauling wood and plowing in the winter, will rarely be used to trail ride (when grand kids get older) and I would only stay on the tote road trails so not expecting to be getting stuck.
Im just thinking having the winch higher up will be better for lifting the plow.
Thanks PHil
Reactions: Buggyman
Buggyman
Buggyman
34,449
294,432
ne. ohio
Thanks PHil
I don't think it much matters, mine will lift the plow clear up in the path of the headlights, probably 3 feet off the ground.
Reactions: mpilihp
