P1000m5 1000-5 Rear Door Inside Storage Modification
107,093
@JTW I found it. It has some give to it but will see. Goes on nice and was easy to work with.
0DB8E345 80A4 475E A940 E3C90416C06E
Reactions: BWAF and JTW
ToddACimer
ToddACimer
Pioneer 1005-2
3,564
14,633
Oshkosh, Wi
Reactions: Bradley-Thornton
39,079
Water proof bags are great. I used several small bags in each door and label the bag so I know what’s in them. They are waterproof and dustproof it also helps keep things from vibrating and making noise.
I saw @JTW labeled the inside of the door which is smart. I’ll probably do that too
Firemedic530
Firemedic530
386
1,122
West Jefferson, Ohio
I went with this weather strip. I have sprayed too much SC1 to try and get something to stick to the plastic. Lol
It will help prevent water and mud from entering around the opening. It certainly isn't a sealed storage though. I purchased on Amazon. It was $49 for 30'
20181224 112106 20181224 112054 20181224 111716
Reactions: Remington
107,093
View attachment 98901 View attachment 98902 View attachment 98903
Looks like the one I did on post [HASHTAG]#294[/HASHTAG]&301 but yours looks a little bit Wider maybe cover some more area . I haven’t had a chance to try it yet and see how it does.
107,093
Yours is adhesive and mine has the u channel to hook over the edge. The adhesive wouldn't stick on mine.
Roger that. I use 70% rubbing alcohol to get rid of the SC1 to make things stick. That’s the only way I could get my stickers to go on. But that is a good idea and alternative you have there.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
@Remington - I ordered the same as yours after you ad posted about.. I have been out a couple of time and it seems to help. It has not been real dusty the last few times out but I do notice that there is min amount of water if any after washing the Honda on the contents that are close to the door hole
107,093
Sweet! Good to know. It was an idea I had from buying the seal for an RV I was fixing up. Had half of a roll left over and thought??? What the hell! Couldn’t hurt. Sounds like it was better than a couldn’t hurt! Lol thanks for the report.
39,079
Does anyone else forget what they put in the doors and look all over for an hour then remember it's in the door??
I do!
I seen JTW use a marker and write on the inside of the door which I thought was a good idea. I use dry bags and write on the outside of the dry bag
NTCPrezJB
NTCPrezJB
President of #NTC
101,343
905,219
Canton, OH
I do!
Someone please tell me he also drew a penis on the inside of one. I will be so disappointed in him if he hasn’t.
