Shorter yes but narrower?I need to make the car about 3-4 inches narrower.
Do you have a winch point on the TH?Great idea, I have seen some people do that, my concern on doing that is that I have to load it on a toyhauler so its very steep going up, even if I made the wood bigger to clear the ground clearance for the ramp, I dont think I would have enough traction to climb the ramp.
Not really but trailer does have airtracks on the floor.I wonder if I can find a spare rim that fits. Like the donut spare tiresDo you have a winch point on the TH?
I'm not sure what airtracks are. Maybe someone else would know about the donut rim too. I always thought the wooden wheel guy should make some out of aluminum. Maybe you could go that route? Just an aluminum disc. I'd trust that more than woodNot really but trailer does have airtracks on the floor.I wonder if I can find a spare rim that fits. Like the donut spare tires
Years ago when I was looking for automotive rims to fit, I found only one vehicle that share the bolt pattern. It was 1 year only, and low production. I was trying to find 14" steel wheels and had zero luck at the time.Not really but trailer does have airtracks on the floor.I wonder if I can find a spare rim that fits. Like the donut spare tires
Great idea but like @Neohio said finding one with the right bolt pattern will b tuff.Like the donut spare tires
Stock setup. 1.5spacers. Does fit but its way to tightGreat idea but like @Neohio said finding one with the right bolt pattern will b tuff.
What size tires and spacers you running that it won't fit?
Like how tight? As in rubbing real bad or just close?Stock setup. 1.5spacers. Does fit but its way to tight
my P1K5 and my X2 both with 30’s and 1-1/2“ spacers and 2” on the x2 are real tight, like 5-6” each side or less In my TH. Inclosed trailers are always super tight with our SXS’s especially with mods like spacers and wheels, your just hauling it Not staying inside when your transporting it I hope lol. You made it sound like it would fit at all as like the trailer builder screwed up! 😂 Unless were missing something?
Got any pics of what your talking about?
where can I find those?You need a skinny set of transport wheels to load and unload, then change to your riding set.
Take notice, I didn’t say it wouldn’t be a PITA.
I have no idea, but I think that’s what the monster truck guys do to transport their buggies.where can I find those?
Would it be just as easy to take the spacers on and off as it would be to swap tires and wheels every time you load it? Sounds like it does fit now without the spacersFits but I want to add spacers. And the 3 extra inches that would gain is all I had to play with.
