So I recently installed a Superwinch Terra 45, front 21" LED bar, and rear 8" LED bar along with the associated switch plate on my Pioneer. To light the LED switches and relay for my winch I spliced into the 12V accessory plug for ignition power using a T-Tap connector. Upon initial install everything worked fine, LED switches were illuminated and the winch functioned, note I had not pushed the rocker switches into my switch plate securely.
Yesterday I pushed the rocker switches into the panel to secure them and now all of a sudden I'm blowing the 10A fuse for my accessory plug. Going to try and eliminate the issue by accessory once I go out and get some 10A fuses. I just wanted to throw this up on the forum to see if there were any similar issues out there...
Thanks
Thanks
