P1000 14" bullet hole steel wheels
500
500
589
932
4x137 bolt pattern
14x6.5
4/2.5 offset
$160 per set of 4 if anyone is interested.
Center caps included.
IMG 20180103 160034811
500
500
589
932
Is that the same width and offset as the factory wheels I'm having trouble finding that info
No. Factory wheels have different offsets and width front to rear.
Fronts are close to 4.5/1.5
Rears are close to 5/2.5
Those numbers aren't exact, but close enough to get the idea.
500
500
589
932
These would keep the rear track width about the same and bump the front out a touch wider by an inch or two.
Mtnman
17
12
maryville Tennessee
Ok thank you so they are a little narrower than the rear factory and a little wider than the fronts?
500
589
932
No.
The reason putting these on the front would increase the track width is because they are slightly more offset, not due to rim width. They are about the same total width as the stock fronts at 6.5".
