P500 2+5 Offset??? With 30x11-12 Interforce?
K
kyote
66
241
La Porte TX
Anyone running 2+5 offset on all 4 corners?
Trying to punch out the wheels for stability as much as possible, would rather run more offset than spacers.
Also planning on 30x10-12 Interforce all the way around, planning on a frame mod at least.
Planning on cutting up the frame on a brand new 2021 520 :)
Reactions: TripleB
115,791
The tires in question
Only issue id be worried about that big on a p520 is power loss. I had 28’s on my old p5 and it dragged a bit. Id also check the weight with the steel rim and tire. Also unless your planing on building a long travel suspension, your gona need spacers. Its not a bad thing.
@trigger put some bigger tires on and i believe a tuner to get it right. Maybe he can give u some insight.
PS, did u get your machine? Any pics?
LilRedDonkey
LilRedDonkey
180
613
cheesyland
amazon and others do not show the correct item ever. here is a 5+2 in black, and a 2+5 in silver to show the difference. 2+5's will get you some good width.
X002 D1
Reactions: Peter_72
104,903
Might wanna add some spacers too. Seems tippy even with the offset rims
Reactions: RB3offroad
Splorin
305
863
Maine
Not sure if frame mod will be enough because all tires are different when mounted up. Loaded dimensions are all over the place. My 2-5's (28x12 MudLites) are on the rear for a couple weeks right now for late season snowrunnin. 59" and weirdly stable. Way different than low 50s. Fronts are 10's on 4-3s (26.75 actual) and slightly rub unmodded frame. Someone else could have a 28 on a 5-2 and not rub so who knows???? trigger's 28s look big and he did the forward arms to compensate. Keep your goggles handy if poking your head out with 2-5s on the front!
Reactions: futzin and trigger
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Have you been drinking
  • Haha
Reactions: Mudder and trigger
pFive
pFive
668
1,256
Greenwood IN
I think I have that set up...ITP steelies with 2" spacers all around with 30 R-force. But I dont have a pic handy (new laptop) But, I used to have pics in "My garage" on here...https://hondasxs.com/media/flexin.3441/
Reactions: trigger
K
kyote
66
241
La Porte TX
5+2 with 2" spacer would equal 3+4, wonder if that extra inch of offset would make rubbing worse or better?
pFive
pFive
668
1,256
Greenwood IN
I had to cut the frame ends... first week of ownership I think, Also, when the tires are new they can touch the front fenderwell plastic at lock, and the tube/cage that is in the wheel arch. Not enough to concern me, but if packed with mud it can rub the paint off that tube.
Peter_72
Peter_72
792
6,538
Louisiana
Those tires are 41 lbs each, my 28’s are 42 lbs and if I shop on a steep hill or in thick mud it has a hard time getting them going again. I’m about to install a gear reduction to help it.
  • Wow
Reactions: trigger
179,041
Damn man, 168 lbs of tire! What 28's are you running? Even in low?
Alanthill
Alanthill
34
112
Eastern NC
Had to modify frame and that part was easy.
Modifying floorboards were a bear.
Then the mud was slinging Everywhere so had to modify Jeep flares to keep the mud out of the machine.
Sometimes it's just Not worth the trouble.
Oh, KILLED the power too!!!
