hondabob
The Talon is amazing. I'm doing my 3rd oil change and its easy. I made a under roof snorkel as I do on most of my side by sides and clean it at every oil change. The original air filters on my 2016 YXZ are still clean at 20,018 miles. So is my 2016 Pioneer 1000 with 18,600 and some miles. I added a under the hood pre filter. I moved the rear Tender Spring crossover rings up 1/2 inch, 7 turns on the rear shocks. Did 4 more turns, for a total of 11 turns. Moved the front tender crossover rings up 4 turns. I removed the sway bar too. The suspension is great on the low speed washboard. I can still reduce the tire pressure from 12 and 14 to 8 and 10 but its easy to damage a tire with the low pressure.
