Jshell3
So the 24" stock tires are gone, gone.
However, I was smart enough to take a couple measurements before I traded them away.
The New Tires are 26".
I gained 1" ground clearance adding 2" taller tires. Which makes sense NOW that I've thought about it.
If a tire is 2" taller, then it's 1" taller on each side (top and bottom) from center of rim.
And only the "center to ground" inch matters for ground clearance... duh?
But I get the full 2" benefit when it comes to pulling and top speed (and lessening the neck jerk torque of shifting from "N" into "L")
Anyways, the pictures...
