P1000 20 minutes you say ....... LOL
BigOL3
BigOL3
2,994
8,920
I received my auto backup light from Hondasxs store today and figured since I had 20 minutes to spare(as Russ vid said), I would slap that sucker on the P1K. After about an hour of doing contortionist moves and feeling like a pretzel, I finally got the dummy plug out of the wiring harness!!! At that point I came to realize that the allotted 20 min time frame did NOT apply to a STIFF 71 yr old man. Just getting into position to SEE the plug was a major task, I thought I never would get both arms/hands in position to get it apart ..... lol. Once apart, it was easy sailing and works GREAT. Great idea @Hondasxs, thanks.
66,869
Lol.
Plug comes apart easy.
Recomend grabbing the dummy plug (the 2 holes with rubber stoppers) with a pair of needle nose. Then using a small screw driver to lift the tab. Then pull.
5 mins and I can install the whole kit with the exception of zip ties.
BigOL3
BigOL3
2,994
8,920
Lol.
LOL..... but you are a YOUNG buck! Getting TO the dummy plug with pliers for pulling and screwdriver for prying the tab was the hard part.
Russ989
Russ989
22,642
147,257
Yeah it’s in a bad spot, flexibility is key! Lol
  • Haha
Reactions: BigOL3
W
Weasel_master
27
32
Mn
I dont really mud but go through some holes while hunting. Am I better off putting cube lights up top on the corners of the roof? My only concern is will the kit lights get dirty quick enough to be ineffective?
Reactions: BWAF and Russ989
66,869
Up top they wont. The kits that are down low do.
Reactions: BWAF and BigOL3
Haldog77
Haldog77
NTC's Mafia Enforcer
38,866
340,573
Bossier City, Louisiana
I can relate to that. I changed oil and filters today, plus I replaced the air filter. I removed the skid plate to have a better way of getting to the drain plugs. I also extended my fuel tank vent. All in all I need to be in traction.
Jacks
Jacks
320
1,527
South Dakota
I also did mine this weekend. Added the dash switch/harness and mounted it on the middle bar so that I can see into the bed also.. I just had my sons do it :)
Reactions: Isaiah and BigOL3
DAV11
DAV11
105
194
Minnesota
That's exactly how my install went too.
Reactions: BigOL3 and Isaiah
