2012 pioneer skid plate
Monteman456
7
Cortez Colorado
I have a 2021 pioneer 1000-5. Iwas doing some work underneath and noticed all the holes in the skid plate. I have noticed last year riding lots of dust boiling up into the cabin. I covered 16 holes with duct tape. Has anyone else noticed this? Why did Honda make the skid plate full of holes?
63,037
JesseWhat
Fatsquatch
Fatsquatch
Approved Member
121,631
1,013,975
Hidden
I'm going to take a wild guess that this is your first foray into the off road world. The holes are pretty minimal and put there intentionally. Some provide access to things like drain plugs for oil. Others provide a little help with the heat generated by the motor and transmission above it.
The factory skid plate isn't much of a skid plate though. It really does more to keep small sticks and small rocks from being thrown against the expensive parts above it than it does to slide the belly of the machine over a rock ledge or log or an impact. If you stick to mostly well groomed trails, dirt roads, forest service roads etc it will do the job. If you start getting into ruts or ledges or rocks or other belly dragging/smacking items then you would be wise to get an aftermarket skid plate ordered and installed prior to learning the hard way it wasn't adequate.
Welcome to the club.
Pics or it didn't happen.
Red is the fastest color.
#NTC
JenElio
JenElio
82,903
718,430
Loxahatchee, florida
I've used used this in the past, works great!!
61KukVnBzVL AC SY355
And for those hard to reach spots.....
Screenshot 2021 02 02 00 09 562
63,037
For real though... when you say "dust was boiling up into the cab", do you have a windshield? These are not sealed up like a car/truck. They are designed to drain water/mud/etc. When you were under there duct taping holes, did you happen to notice that the entire underside of the vehicle is basically a "hole"? You can pop your seat off or lift the bed and see directly through the vehicle.
Gold-digger
Gold-digger
108
363
Ocean Shores Washington
You guys are 2 much my eyes are watery lol
