2015 Pioneer 500 power steering install
crosby
Cincinnati
My cousin has a 2015 Pioneer 500 and is looking for an
after market Power Steering unit and also how difficult it is to install
Mudder
Mudder
NTC Ambassador of Walls
11,691
88,487
@crosby Did a 2017, should be similar, not difficult. Just may have to take some time playing with the unit with loose bolts to get any flex out of the mounting plate/shafts. BIG improvement. Ask for forum discount if ordering. Good thread with info.
P500 - Power steering install
Mudder
Mudder
11,691
88,487
Got the Superatv ez steer for about $500. Spin wheel one handed.
Reactions: Chooglin
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Just ordered the EZ STEER from SATV. Had it in the cart and was undecided so let it sit there for a week and then received a 10% off code so I pulled the trigger on it today.
671D52A5 2770 468F 8A11 882655B98B1E 10DB224D 1451 48D7 8A87 A833AAF4F671
Eltobgi
Eltobgi
4,599
15,186
North Dakota
You're going to like it , I don't regret spending the money for mine!
I hope so! What pushed me over the edge was really the need to finalize my dual battery set up so I needed to know available space under the hood because I knew that I eventually wanted to get it!
182,144
I found the install pretty easy other than the instructions being wrong, spent a little time figuring that out. Only other issue was watching the up and down flex of the bracket, I called Super ATV about that one and was told it's normal.
Reactions: Eltobgi
GRANITE
GRANITE
People Dying to come see me!
1,123
5,699
Brookville, Indiana
I installed the Tusk version! I was like you wondering about install and if I could tackle it! It’s a lot simpler than it looks. Just hold the plate away from brake reservoir when tightening bolts and make sure it clears shaft. That’s the hardest part! I got mine for $450 after coupon and you get an additional $25 on future order at Rocky Mountain ATV
Reactions: Eltobgi
riderpilot
riderpilot
Southern VA
Anyone got any coupon codes for either the Tusk or EZ Steer? From whatever site. Rocky Mountain ATV, Super ATV. etc. I prefer the EZ steer but whatever works out to be more cost effective is ok as long as they both perform well.
Reactions: Chooglin
182,144
Just call SuperATV and they'll give you $50 off if you mention this forum. That'll be for the EZ Steer.
Reactions: Mudder and Chooglin
GRANITE
GRANITE
1,123
5,699
Brookville, Indiana
RM ATV usually has Tusk 10% off sales around major holidays! I know I'm looking for a new set of beadlocks and Terrabites soon. The good thing about the Tusk brand is its a few bucks cheaper and they also have extra cash with purchase of like an additional $22 bucks. I know I got mine for like $425 after it was all said and done
Bigdrag
11
5
Ojai
And How did you do that?!
Nice..I ended up cutting a ¼ inch from the bracket (enlarging the "notch"). this enabled me to slide the motor and bracket to the left. thanks for your reply! I've a small issue now as it states in the wiring instructions to attach the white wire from the harness to the brown wire from the ignition switch. But no brown wire! I probably just need to find the Switched power lead and connect to that/
Bigdrag
Wallace
Wallace
Well that didn't go as planned
2,813
15,101
Lonoke Arkansas
Bigdrag
Use the wire to 12v socket under dash.
Chooglin
Bigdrag
Have a look at this
P500 - Accessorry sub harness description
