P1000 2016, 1000-5 stalling issue
David Mac
6
Maine
I have a 2016 1000-5 deluxe. Having a stalling issue. Rode about 3 miles over rough trails and start up a hill and machine shut off. Still had power but engine shut off. Rolled back down hill and restarted and tried again, stopped in same spot. Maggie stopped several times going back on trail, all times on a hill. Runs fine on straight trails. Never had this or any issues. Have a little over a 1000 miles. Ordered new plugs and air filter to change them. Also filled up with non ethanol gas prior to problems, but I have run this before with no issues. Any ideas?? Thank you
Reactions: Lady01 and TxDoc
HondaTech
Does the dash flash any codes when the unit shuts off?
Does it shift properly any other time?
Reactions: Lady01
David Mac
6
Maine
Have not seen any codes, and it seems to shift properly.
Reactions: Lady01
David Mac
6
Maine
After reading different threads and more research I think the problem is solved? Cleaned amateur on electric shift motor, and replaced plug end on rear fuel injector after seeing #13 code. So far so good! Thanks for the helpful info and parts!
115,818
Glad she's fixed!
Welcome to the forum btw...
Pics or it didn't happen!
slowdryrider
slowdryrider
574
784
Canada
This is what we need more info on people cleaning up the shift motor and ending up having good results. This hopefully will help others with problems to do with shifting. Thanks for letting everyone know.
Reactions: Lady01 and TripleB
