P700m2 2017 Honda Pioneer 700-2 Deluxe Camo
JeffEvans
JeffEvans
64
106
Arlington, TN
Awesome, love all the detail! Did the sealed box come with the PDM? I like the idea of that chain, but with the advent of the battery powered angle grinder, I think any security chain could be ground through in a minute or less.
Waylan
Morning! The sealed box came from Wal-Mary for about $6. Just wanted to keep any direct water from getting to it. I also have the hole for my wires drilled at the bottom of the box in case I do get water in there...lol!! But I'd have to sink it pretty deep in order for that to happen.
On the chain, I can't remember how long it takes to cut through it with the grinder, but it was over a minutes to cut through one side of it. The thief would have to make 2 cuts to get through it. And they would have to put it in a bind to keep it from walking on them. Check out the video on the 1st Chain website...pretty cool video about the chain.
My hope was to make my SXS not an easy target and a thief wouldn't chance grinding for over 2 minutes (lots of noise) to get mine...just move on as bad as I hate to say it...to an easier target. I'm also thinking about putting a GPS tracker on it. Not sure if anyone has any thoughts on that.
Thanks on the detail comment...my hope was to try and help anyone that is new to upgrading their SXS. I learned so much from this forum! Lots of great ideas and folks on here!!!
Reactions: Tflynn
AlR
AlR
470
1,166
Nanaimo, British Columbia
I think the top spot is where my light bar will go. Thoughts on the cheaper ones from amazon vs the rigid ones?
I have both. Rigid is awesome but Chinese lite bars are 15% of the price. I've run the Chinese ones on the quads, trucks and tractor for years without a failure. So... as much as its good to buy local, I kitted out my P5 with 5 Chinese leds for less than the price of one Rigid.
That's my $0.02
Al
That's my $0.02
Al
Rigid for highway vehicles where you need a long light throw. Their reflectors are better. Amazon specials for everything else.
walexa07
walexa07
396
380
Louisiana
I've called myself studying your wiring diagram, but it almost looks as though the accessory power wire goes to the switch as well? - does the PDM60 have a separate trigger wire that goes to each switch?
Thanks,
Waylan
Reactions: JeffEvans
JeffEvans
JeffEvans
64
106
Arlington, TN
Thanks,
Waylan
One clarification...there is a black ground wire coming out of the voltage meter that is not there and I should have scratched it out as well.
So...the PDM is grounded to the leg that all the switches are grounded to and the Ground Trigger Switch is connected to the ground trigger wire coming out of the PDM.
The ground coming out of the Ground Trigger switch is connected to all the grounds as well.
Sorry for the delay on the response.
Ems-Cam
Ems-Cam
252
336
Alberta
Front EMP Bumper with Superwinch Terra 45 S installed!
267d3a7271935fe64f92b7b5f3ef83b49a5594170fb446d79fb14ceca353567b
Got a favour for you or anyone with the 700 and an EMP front bumper. Need the measurement for the front bolts on the bumper, top to bottom. I wanted to add a bolt on D-ring but need the bolt spacing for the holes, and 120 miles from home stuck at work. I wanted to do my research while I have time.
Thanks.
JeffEvans
JeffEvans
64
106
Arlington, TN
Thanks.
I like you're thought process on that...center to center...2 9/16.
Ems-Cam
Ems-Cam
252
336
Alberta
Found these.I cannot claim the brilliance for this, I saw a picture and thought it was a great idea.
Screen Shot 2017 01 30 at 25328 PM
JeffEvans
JeffEvans
64
106
Arlington, TN
Got the rear panel installed today!
541ef54dc7e0d4a53c2f75299b9dc34f
Reactions: Ems-Cam
JeffEvans
JeffEvans
64
106
Arlington, TN
Rear LED Light Bar installed along with LED Pods for the bed and dome inside!
8bf6e54fbf7a1d64cebd632b0b1e9b3b4a9335f6fab793a60d226e5a6f4ab22f0e54e8d9f4717df5914f57baa030f7f4
JeffEvans
JeffEvans
64
106
Arlington, TN
Now for the switch plate...starting to see the light at the end of the tunnel...lol!!
C15f4afb70e136305fb6ee8b8ecf41fa
JeffEvans
JeffEvans
64
106
Arlington, TN
The hard work has paid off...only thing left is the windshield that didn't come in and then install the front light bar...already wired...just got to plug it up!
D618f266e743ebeaa14146dac75e9833E3609dfe09fdc077207d2cab0ef66f66
JeffEvans
JeffEvans
64
106
Arlington, TN
Well...I forgot about my mud flaps...Mudbuster flaps about to be installed!
500081f3f64f1923eccd9b6a24c150c8
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
Will you PLEASE go get some dirt on that thing?
You're killing me. Mine is sooooooo dirty. I can't post pictures because, compared to yours, mine is unworthy.
JeffEvans
JeffEvans
64
106
Arlington, TN
I finally got some on there today! Lol!!
Only two more "clean" pictures coming...my mud flaps!
I'm done upgrading for a week or two. Mud pictures coming soon! Lol!!
JeffEvans
JeffEvans
64
106
Arlington, TN
Really like the mud flaps! Mudbusters is the way to go!
57762bfe452438a1709f204b467438f548947f2a4fe1df82df0f97fb915e6bd1Da7d4b2eed0d250920c0f508cdae128d926a7370fcdbe6c6449206c9c838fe87
Reactions: joeymt33
T
teejk
15
Hatfield Wisconsin
Yeah the price of the super winch is tough to beat. If I were shopping for a winch today I would really give them a hard look.
Without searching the entire site, is there a "consensus" on winches? Sounds like Warn vs. Superwinch.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I would say you're right, it's warn vs. superwinch. As for which is better, I can't say...but for what it's worth, I have a warn
Reactions: Donsavage
