P500 2017 seatbelt safety disable
Neohio
Neohio
Beast of the East
21,740
93,110
Painesville Ohio
Maybe I will remove the talk of using a bypass in this thread? Seems to be confusing some people. The mod to the buckle is good, is free and works as promised. The bypass was used when the stock buckles were REMOVED from the machine and harnesses were installed in their place. I didn't want to ziptie the stock buckle under the seat. I wanted it removed and thrown in a box for the owner to do whatever he wanted with it.
  • Love
Reactions: Mudder and monkfarm
Mudder
Mudder
NTC/TAP Transition Member
11,865
90,391
@JTW , maybe a good point to change title to Seatbelt Speed Limiter Disable, might help future owners with Search/description. One of the best easy mods along with the reverse lever adjustment.
seymore13
seymore13
9
Just picked up my 2017 P500 two nights ago. Did this mod last night and it worked like a charm. Now to find some flexible straps.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I like it. I think I'll do it just because even when they're buckled I often have to unbuckle and buckle again (why?!) to the the speed limiter to shut off.
Reactions: Mudder
2018GMC
2018GMC
174
356
AZ
Just did this on my 1000-5.
No more flashing seatbelt light or speed limiter.
Thanks for the pics and write up!
HappyCamper
62
103
Wyo
Thanks for the info. I get tired of doing and undoing the belt when I have to get in and out frequently!
Reactions: Mudder
dougbo44
23
67
South Jersey
2021 seat belt harness is not the same. Also it is NOT under the seat.....
Mudder
Mudder
11,865
90,391
Welcome to the group. There is a plug available in this forum store section, and post #42 here if you are interested.
Reactions: Bigtee
