P1000 2018 1000-5 Deluxe build help
E
Emmer75
20
7
Ohio
Ok folks I am once again in need of some guidance from those that have been there and done it. I am in need of more ground clearance for trail riding. Most of my riding is done in the Midwest, wildcat, rush off-road, Tennessee trails, sand dunes and some light street riding. I need to clear the deeper ruts and rocks. So what setups are y'all running to gain some height but also be safe. I wanna run 30x10x14 Terrabites on all four corners. Ive looked at the super atv lift and arms set up and the cfab set up. I'm not opposed to changing out the shocks if necessary. Any insight and guidance is greatly appreciated. Thanks
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
28 inch tires are max on stock set up. For 30in You'll need the offset A arms from Super atv on all 4 corners. You wont need the lift. Do you have the fox shocks?
With 30's you're going to lose some low end power. You may consider IGR depending on where you ride the most.
@joeymt33 @Ragnar406
115,818
Exactly what ^^^^^^said;)
E
Emmer75
20
7
Ohio
Stock shocks on it now. I know nothing of the IGR???
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
IGR = Internal gear reduction
You will feel some loss of power when you go to a bigger or heavier tire. I don't think it is too bad running 30's in fact when i first went to a larger tire it made low more tolerable. Your big challenge will be clearance - Usually to run 30's you will have to add forward A arms such as the ones from Super ATV. If you ahve a 1000-3 you can get away with just the fronts but with the 1000-5 you will likely need fronts and backs. Each tire is a little different as well as tires that have a rounded profile like the Terrabites vs a more square profile. @Hondasxs run the 30' Terrabites so I will see if he can comment on the SATV a arms with that specific tire.
I for one had a lift but did not like way it stiffened up the machine. If you had aftermarket shocks you could add a little preload to them to get your ride height up a little bit.
Reactions: TripleB
Frogtown
Frogtown
195
1,484
Kentucky
I recently went with 30’ terrabites. I only put the front super atv a arms on and I have stock shocks with spring spacers for some lift.
E
Emmer75
20
7
Ohio
Did you do spring spacers on all four corners and arms in the front?
Frogtown
Frogtown
195
1,484
Kentucky
Spacers all around. I think i gained an 1-1/2 ground clearance
