2018 P1000-5 Rattle in motor
Hello_Darkness
Hello_Darkness
623
2,555
Just to the right of nowhere
No I’m saying I’m going to do both. Isolate the motor off trans and also pull the pan. Truly hoping it is possibly just the clutches. I appreciate all the help gentleman. Hoping I can get this figured out soon and hit the first honey hole.
Taking the clutches off means removing the whole rear of the engine, then I don't believe the engine would start due to transmissiom oil pressure issue possibly.
Reactions: ChadD and Rayger143
Duramax1021
12
37
Key largo
IMG 0215
Just realized something. Isn’t there supposed to be a guide between the chain tensioner and timing belt? I’m not really seeing the chain get any tension from the tensioner at all.
Reactions: ChadD
Hello_Darkness
Hello_Darkness
623
2,555
Yes, there should be a "guide" on both sides of the timing chain. One is usually a yellowish plastic and the other has rubber edges molded to a metal center.
I think you found your noise.
I would definitely replace the chain and tensioner foot for sure.
906UP
906UP
14,915
141,772
da Yoop
Not sure if you're following what @Hello_Darkness is saying, there is no "removing the transmission".....it's inside the engine. The subtrans is just a transfer case, nothing is spinning if the buggy is stationary.
Reactions: ChadD and JenElio
906UP
906UP
14,915
141,772
da Yoop
Question is "where did it go?". Better pull the oil pan also and clean out the debris
Similar threads
