P1000 2018 Pioneer 1000-5 Camo Deluxe Build
jake_r15
jake_r15
7
PA
This is my first post to this forum. I purchased a 2018 Pioneer 1000-5 Camo Deluxe back in November. Since then I have been accessorizing to get it where I want it. I will add pictures and reviews of products along the way.
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
Congrat's on the purchase - love the camo and welcome to the forums!
E
elkguide
3,377
7,964
Vermont
Welcome to the addiction.
Join in the conversation. Great place to be.
ENJOY!!!!
Koda
Koda
565
2,309
Canton Ga
Welcome from North Georgia
jake_r15
jake_r15
7
PA
DSC00098
Installed the SuperATV Honda Pioneer 1000 Scratch Resistant Flip Windshield and love it. Love the ability of flipping it all the way open or partial for a little air movement.
DSC00098 DSC00070
jake_r15
jake_r15
7
PA
I'll post my review of my Moto Alliance Viper Winch and Denali Plow Setups when I get a chance.
E
elkguide
3,377
7,964
Vermont
AWESOME!
Let the "SPENDING" continue!!!!
I
infernored1000
219
262
Congrats and welcome from mid Missouri
jake_r15
jake_r15
7
PA
Moto Alliance Viper Winch Mount / Denali Pro Plow Setup - Not many companies offered a winch setup that was verified for a 2018 machine. I did the Fitment verification for Moto Alliance on both the Viper Winch and 72" Denali Pro Plow Setup. I will say the whole system is very well built using heavy gauge material, however things didn't just "Fall into Place". The winch Mount Bracket collided with the Frame Gussets as shown in the pictures.
Here is some of the feedback I sent them, so I'm guessing some changes may occur due to my input or you may have to do some modifications to make things fit nicely.
It was not a smooth install, but end of the day, they are both installed. I don’t know if it’s slight variations on a 2018 machine or just variance in manufacturing of the mounts.
Winch Mount:
· Top of the Winch Mount Plate collided with the frame gusset.
· Bottom of the Winch Mount Plate collided with the mount for the Front Diff.
Outcome:
o U-bolts aren’t long enough to install per directions and draw the plate up tight to the frame. Must install the bottom ones backwards initially to “Form the plate”. Hoping the winch still mounts to the plate ok.
Suggestions:
· Plate should be notched around the Front Diff Mount and it would probably fit nicely under the Frame gusset on top and around the diff mount.
· Why not just put the rounded section of the U-bolt around the round frame as well?
Plow Mount:
· Front 2 “Ears” are too far apart making the supplied bolts almost too short, (Some required “shaping” not using the 2 recommended washers). This also left a gap between the “ears” and the bumper frame.
· Holes are drilled too low in the “ears” to line up with Factory Bumper holes. Had to use a floor jack to line everything up.
Hoping I don't have to remove, because the passenger side maybe cross-threaded now.
Suggestions:
· Ears should be welded onto mount closer together, or longer bolts with spacers.
· Holes need moved up in ears.
Plow:
  • The mount on the plow where it bolts to the push tube was smashed on the passenger side, See attached photos. Had to do some "pry bar work" to bolt it up to the push tube
Fit Frame Gusset Gap Points of contact DSC00091 DSC00093 Bent 1 Bent 2
E
elkguide
3,377
7,964
Vermont
WOW!!!!
Kind of a funky set up.
My Warn winch and my Moose plow have had zero issues and it was a breeze to hook up.
