Member ** 2019 ** Colorado Ride Sept. Pre-Planing
What dates work best for you?
  • Aug 30th-Sept 2nd.
    Votes: 5 27.8%
  • Sept 6th-9th.
    Votes: 10 55.6%
  • Sept 13th- 16th
    Votes: 3 16.7%
  • Total voters
  • Poll closed .
SouthParkColorado
SouthParkColorado
150
643
Hartsel, CO & Aurora, CO
www.flickr.com
  2. Other Brand
@SouthParkColorado
How is the Paved roads leading into Taylor Park? What's the best route for motorhomes and or toyhaulers?
Until the new Cottonwood Pass road is finished, the only paved road into Taylor Park is through Gunnison, CO.
It's busier than normal, but it's fine [if not very wide] for anything you might wish to bring up. Just a couple weeks
ago I visibly saw several hundred large and monster size RV's and toy haulers in the area.
7,140
27,147
I'm guessing you have stayed there a couple times? If so do you think a group of 20 or so Hondas could use it for a 2 to 3 day starting point.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I went over tincup pass... Cumberland pass to pitkin... and back over Hancock pass to st Elmo.. Wednesday last week.... then did mount antero last Saturday..... all good rides.... the st Elmo loop,was a little long for my 5 year old granddaughter... it saw a moose coming back down Hancock pass and she was good to go...
This is a dumb question but where is the St. Elmo loop? I am going out to do some riding in your area in a few weeks.
Reactions: BWAF
SouthParkColorado
SouthParkColorado
150
643
www.flickr.com
  2. Other Brand
Google Maps
This could be called St Elmo's Loop, though you could start it at many
different points and you could go clockwise or counterclockwise...
Oh, and no cars need apply and 2 hrs 27 minutes ain't likely either.
Double that or more.
Wider than 50" version:
Google Maps
7,140
27,147
Ok I talked to the people about the cabins and RV park( separate establishments)
First off there looks to be availability for cabins for September of 2019.
The RV park also has spots available. Only problem is the RV park closes down when it gets really cold and or snowy. So they dont suggest anything after second week of Sept.
I'm going to start a poll and see what dates work for the masses. Also need to find out how many will need cabins and RV sites.
Cabin deposit and cancellation policy is as follows.
Deposit is 1 nights stay of the cabin you select.
Cancellations more than 30 days before are refundable all except $25.
Less than 30 days no refunded deposit
RV CC #to hold spot, will charge your CC when you check in.
Taylor Park Trading Post
66,332
Sounds great let's do a date. Too bad it has to be the start of the school year.
7,140
27,147
Texas will be turning out for the 2019 Takeover!!!
coustom Texas group name and sticker?
Reactions: BWAF
7,140
27,147
Timing of the date for me would work much better for late August-early September
Actually the 30th thru 2 is good with me also. But I'll go with the majority vote.
Reactions: BWAF
