2019 Talon X front diff seals leaking at 230 miles
highpocket74
highpocket74
2,037
6,622
Kinder, Louisiana
www.10-80dirtsports.com
Has one else experienced this problem? I just noticed this weekend that both side seals were leaking, right side much worse than left side? What is this crap? I have almost no miles on the machine and seals are already leaking? Sounds like Polaris quality, except I never had a seal leak on those!! I bought this machine to NOT work on it!!!
spentcoins
spentcoins
52
70
Alabama
Take it in for warranty or buy the $5 seals yourself and replace them, not that big of a deal. They must have had a bad batch of seals or were installed wrong. My right side was leaking at 40 miles. Replaced it myself because I didn't want to haul it to the dealer. I have since had the sub transmission rebuilt and both rear axles replaced under warranty. My machine has around 500 miles now. Still wouldn't go back to a belt. LOL
Reactions: CumminsPusher
highpocket74
highpocket74
2,037
6,622
Kinder, Louisiana
Now that is helpful info! Thanks. It will go for warranty repair when I get to it. I could do it myself but that’s what I got the $$$$ extended warranty for.
PhilCod
PhilCod
354
729
Indiana
I had the same issue with a Honda Rincon I had. Agreed, bad axle install and that jacks up the seals.
PaulF
PaulF
1,462
4,815
Have them check the diff vent lines too. There are other (unconfirmed) reports that the factory applied too much glue at the point where the hose meets the nipple where it goes into the frame. This caused the tube to be plugged and pressure built up in the diff when it got warm and caused the seal(s) to leak.
Again, this is completely unconfirmed but worth looking at to see if it is truly a possibility.
U
Ugly
East Tennessee Mudder
387
894
Rocky Top
Wow, you guys are outstanding. I would have never thought of a bad axle install. Experience (and the HondaSXS club) is the best teacher. That one answser pays for the lifetime membership.
Ken
highpocket74
highpocket74
2,037
6,622
Kinder, Louisiana
It's at the dealership this week. Hopefully they fix it. Don't really like the closest local dealership. Only one person I've met there is remotely friendly. Wanted to try a different dealership but they were 4 weeks behind on service!! Dealership i bought from was great but also 3 1/2 hours away.
5,488
25,254
OMG, I'm a victim 😭 - my left front is leaking at 300 miles. Aborted my SxS trip thru the Rockies and trailered straight to the dealer. Yep, leaking seal, we'll order one and call ya. Well, except Honda screwed up so many of them that they're backordered, delivery unknown. :(
The shop didn't keep it though, "Keep it full and ride it, we'll call when we get 'em in."
Reactions: Mudwing
PaulF
PaulF
1,462
4,815
Check your vent hose. I have seen a few more people saying the hose and/or nipple is plugged with glue and it can cause pressure inside the diff when it gets warm and pushes oil past the seals.
hondabob
1,281
5,088
Prescott Valley, AZ
I grease the seal, line up the axle carefully and turn it as I insert it in the dif then line it up pull it back 1/8" and have someone hit the end of the axle with a big rubber mallet to pop it in.
Reactions: CID
5,488
25,254
Might be easier said than done. The vent line is glued(?) to the upper nipple, I couldn't separate them but I was able to remove it at the lower nipple and hear 40 pounds of air pass through. I didn't want to force it apart, it might fall off later and I didn't know what glue they used to get it that tight (I was pretty persistent before surrendering).
It vents into the frame above the ABS/I4WD controller -
I VvD9MKq L
I was able to remove the vent line at the differential where it's held by a small wire clamp -
I V42bqgj X2
Also accessible from behind the RF shock, sorta -
I cjmnjmn L
Reactions: Lil_Steve
Hometeam
Hometeam
995
4,154
Normal, IL
What's going on with site software, I can't post full sized photos, thumbnails only. :confused:
If you were able to get air pressure through it then your vent line shouldn't be the problem. It shouldn't leak enough during rides to be an issue. But I would check/fill it between rides!
Reactions: CID
Kurtgo1
Kurtgo1
New Mexico
  1. Talon X4
We are about to take our 2020 Talon 1000x 4 in for its 4th repair of a leaking boot, front driver side. It’s getting old.
  • Sad
Reactions: CID
PhilCod
PhilCod
354
729
Indiana
Is the boot leaking or the differential? If its the differential check the vent line if you haven't done so already. If the boot is leaking all the time that is a whole different issue.
Reactions: CID
