P500 2020 500 with CEL
buford1983
7
Tampa
2020 Honda 500 has a check engine light, Neutral flashes with CEL flashes. It just came back from 20hr maintenance and ran good. I thought it was bad fuel so I siphoned it out and put fresh fuel in. It barely starts, barely idles and dies when I hit the gas pedal. Any ideas? I'm new to the UTV world
Reactions: Isaiah
ShotgunClay
ShotgunClay
172
594
Founders Ranch New Mexico
Just went through my second bout of water in the gas. Wouldn't start, but everything else seemed normal (no lights or weirdness on the display). Pulled a couple gallons of gas out, got it going but rough, finally started running normally again. Don't know what gremlins you've got, but good luck.
buford1983
7
Tampa
just stays in neutral
20201004 184521
buford1983
7
Tampa
Coolant temp sensor indicator is on too so that may be it
43,292
Is there a pattern with the CEL? If its the CTS, the fan will run anytime the key is on.
43,292
9 shows as the Intake Air Temp sensor on a 2019 service manual.
