2022 Pioneer 1000 Model Announcement Today, Honda REDLINE
TripleB
TripleB
18,098
161,821
Caryville, Tennessee
New for 2022:
Sealed Cabin: On all Pioneer 1000 versions, a number of measures were taken to isolate the driver and passengers from engine heat, as well as external debris and moisture.
I love this one. Have a 2021 and the seat can get so hot. Sounds like they made it a priority to improve the cabin comfort. I would have loved to see an improvement to the cab enclosure so I can properly enclose the cab for winter use.
Don't get your hopes up on that. I bet it's very minimal at best.
Reactions: Buggyman and Lady01
TripleB
TripleB
18,098
161,821
Those parts were mentioned by @HondaTech a few months back, and yes - all parts are available to update your subtrans. It's mentioned in the later pages of my subtrans thread.
One thing I'm not clear on - did they change the reverse gears, or does one still need to swap in Talon reverse gears if you want a lower reverse?
I dont remember seeing any thing about updated gear ratios in that thread. Just the few updated parts to address the low/reverse grinding. This announcement says updated gear ratio.
TripleB
TripleB
18,098
161,821
Fix the low/reverse issue, which they have. Fix the font upper a-arm issue, which they have. Some real wheel travel, they didn’t. A truly low range, they didn't. If they would've addressed those last 2 issues, i would upgrade my Pioneer for sure.
62,187
It's there on the Deluxe models. It's just black like the sticker. You can see it if you look closely:
Same thing on the Trail (matches the red sticker):
The bare plastic has ridges in it (you can see it on the base model):
Screenshot 20220329 202028
You can see the black rear panel on this one. Really stupid looking on the camo machine ...
P1K5Dave
P1K5Dave
2,312
8,608
Petoskey, MI
I did see that on another reading. I did a little digging and saw that the part numbers on the reverse gears were different for the '22, but were not the Talon reverse part numbers that some of us have installed. I guess it'll take a little while to sort out the changes in the subtrans...
It's quite likely that you'll be able to swap in any/all of the new parts, I'd say.
HondaTech
The 22 Talon is getting the same gears as the Pioneer in some cases.
TripleB
TripleB
18,098
161,821
Well hell, I've already bought the talon reverse gears. With my luck, I'm sure the new pioneer gears will be even lower and I just wasted my money on the talon gears.
P1K5Dave
P1K5Dave
2,312
8,608
Petoskey, MI
Well, for the record the reverse drive gear on the '18 Pioneer was 27 tooth, and the Talon gear I replaced it with was 25 tooth. The reverse idle gear was listed as 16/20 for the Pioneer, replaced with a 16/22 for the Talon.
I haven't seen tooth counts on the 22's gears yet.
HondaTech
The reverse idle is 16/22 but a different part number. The reverse gear is a 25, and both are the same for 22 Talons as well.
HondaTech
How do you mean "in some cases" @HondaTech? Are they running different ratios in different models?
I was referring to some of the gears being the same for Talon and Pioneer and some not.
High on the '22 Pioneer is not the same as '22/'21 Talon.
Low is different as well, '22 Pioneer is different then '21 Pioneer snd '21/'22 Talon
Some gears in the main trans are not shared either and some are.
Russ989
Russ989
22,645
147,291
I think if they would have addressed wheel travel, reverse and the A-arm tabs along with what they’ve already done it would have been a major improvement.
