2022 pioneer 1000
WagginTail
WagginTail
1,484
5,482
SC
No way 16-22 model year is accurate. Only 16-21.
A man buys 30 -32 tires. $1100
A man then buys 1.2-2" forward A arms to accommodate tire diameter. $600-$900
A man finds out the 32" still rub add lift kit $200
A man then find out steering rack doesn't handle that heavy tire combo on front. Better Steering rack $600
Machine now feels like a sluggish P700 with clogged air filter. Goes with gear reduction or Portals reduction $500-$3000
Sure is a lot of money for cool looking big tires when 28" will go 99% of the same places for $5000 less. I think those people should start squatting thier Pioneer so we can spot them far off.
Yep. That's why I went with 28" tires instead of 30"
208,029
The 30's work great w/ $ 600.00 dollar A arms front and rear if you do it yourself. I've been on trails that I 4WD units stacked or winched that were with me, the 30's work fine and the 1.5 inches of added ground clearance is nice from stock, but I've been known to get off the beaten trail. And still run stock width.
267,250
That's because Rooster, you're 70+ and pull a cork more than sit in the saddle 😆🤦🤷‍♂️
Ryanp502
Ryanp502
34
122
New Haven Ky
Here’s a pic as it sits. Waiting for the rear panel, lift, tires/rims, wiper kit and cover. So far I’ve got the winch installed, roof, hard doors that need to be installed, tracks and a heater. I’ll be posting updates as more gets done to it. Still looking for a interior lighting setup and a sound system.. too many options out there lol
This is my 22 pioneer 1000. I’ve done the duel battery with a stinger relay and fuse box for accessories. Roof, windshield and mirrors. Going to add the bigger brush guard bumper and winch soon.
5E26A7E6 64AF 40C7 98C1 3F779357AAA6
ODAMO
ODAMO
1,177
3,206
You guys are forgetting this is a 2022 the out put high range gear in the sub transmission is 47 tooth instead 49 like the 2021 thru 2016's so first through fifth gear is lower, sixth is higher it will be tuff to pull sixth gear with 32's but first thru fifth will feel like it's on 30's.
With the 4.8 HP increase and the 4% lower gears it feels like alot more than the numbers would indicate.
