My door latches have never properly met the lock assembly since new. From the factory, the latch adjustment on the UTV was bottomed out, not allowing you to adjust when closing. Passengers would slam the door to close or fail to close the door fully. Hinge bushings helped to remove the "slop" of the OEM bushings, but it still didn't allow the door to meet the latch properly.
I printed some 2 and 4mm wedges for the bottom front door hinge, and have much better engagement of the door on closure with the 4mm set. Just remove the bolts and place the shim between the door frame and the hinge.
For those without access to a printer, you could use paint sticks or wood shims, but this blends right in.
2mm and 4mm STLs attached.
* added STL files
r/Wade
* added STL files
r/Wade
