P1000 26.5 x 11 x 14 Pitbull Growlers all around
W
White-1000-5
11
Kentucky
I was wanting to do 27.5x11x14 all around but since the tires run little larger I would have to do front spacers then not guaranteed to fit all stock. How do you guys think my pk5 Deluxe would look with 26.5x11x14 Growlers all around? Im thinking I could run them without spacers. Im thinking they measure about 27" even though most of that is because of the tall lugs on them. Anyone know what the stock 27x11x14 Bighorns 2.0 measure new? I would be mounting them on aftermarket wheels unless I could find 2 rear Deluxe wheels to mount on front of my machine. THANKS
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
The rear deluxe wheels will not fit the front. The offset is different. I'm looking at these tires or the rocker as well. Why don't you get the 27.5x9- 14 for the front and 11 for the rear? With stock wheels you can't rotate anyways. If I end up going with standard bighorns then I will go 28x10-14 all the way around, but still can't rotate with stock wheels. I'm just worried about durability on the pitbulls for the price.
W
White-1000-5
11
Kentucky
The rear Deluxe wheels do fit just fine on the front with the stock 27x11x14 Bighorn 2.0 as I just took my rear off yesterday and installed on front to see. I like the looks of the same size tire all around plus I can rotate them. I have ran several sets of original Big horns and two set of Growlers on my atvs. I really like the original Bighorns but I loved the Growlers they were a better all around tire other than not wearing as well as the bighorns but still did well.
IMG 20180722 185808
Reactions: Plumber32
Firemedic530
Firemedic530
387
1,133
I sit here corrected. I haven't tried it, I just took the advice on here that you needed a front to use as a spare.
I like the looks of the growler and rocker and the bead protection, I'm just concerned that they might wear out quickly and they are expensive for that.
The reviews I have found online are mostly on ATV and these are alot heavier.
My plan is to put my stock big horns on my 2014 Rancher. The 4ply should be plenty for it. I can't afford wheels for both at the same time.
Firemedic530
Firemedic530
387
1,133
@White-1000-5
Pitbull is running 50% off until midnight tonight. I just ordered my Rockers.
$500.00 for all 4 shipped.
