P500 3" lift
illinoisdave
illinoisdave
74
southern illinois
i bought the OUTKAST FABWORX lift for my machine and got it installed. everything was fairly straight forward and of course i refined a little along the way
IMG 20170630 165734210 IMG 20170704 134857432 IMG 20170720 223304774 IMG 20170720 223256721 IMG 20170723 144108137 IMG 20170720 215806038
illinoisdave
illinoisdave
74
southern illinois
this moved the front spindles forward. i have 14" of ground clearance with 29.5" tires. i have not done the frame mod and it clears fine. i have 2" spacers on the rear total width across the back is 56". i am trying a couple of different spacers on the front to see what works best. looks like it will definitely need fender flares
196,184
illinoisdave
illinoisdave
74
southern illinois
i am 54" total across the front with no wheel spacers. i am running 5 + 2 wheels all the way around with 29.5 x 10 x 12 tires. the rear has 2" spacers on both sides and is 56" across. it handled really well, i know with big tires and a lift you dont corner fast but on the trails it felt really stable. the bigger tires have a little more bounce to them that smoothed the ride out some and roll over obstacles easier. front tires stick out past the fender wells probably 2 1/2" to 3" on both sides. rear is about the same. fender flares or extensions will be needed unless you like to get muddy :D
U
uconn411
160
255
CT
Did you buy New axles along with this kit?
Reactions: Jbrunk
