P1000m5 30” tire needs
MississippiSteven
MississippiSteven
6
Mississippi
I want to run 30” interco interforce tires on my 2016 Pioneer 1K-5. What do I need to add so I can run these tires without rubbing.
nbomar
nbomar
4,416
17,855
Springdale, AR
Not sure on interforces. The standard reply for most 30’s is at least forward offset control front and rear. Some of the bigger 30’s need the highlighter 2.5” bracket lift also.
pct
pct
Lost in the hills
790
1,023
Letart WV
On mine anytime I change tire size I do a clutch reset
Reactions: BWAF
MississippiSteven
MississippiSteven
6
Mississippi
The SATV arms dont add lift. They move the front hubs forward 1.5 in. And the rear 1.5 in back. You may need the lift to clear them if they are true 30 in tires.
I was looking to order the high lifter arms
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Ahh..ok. i think their arms move the hub forward on the front not sure about the rears. The forward and rear movement of the hubs is where you get your tire clearance. I do know the HL dont have the adjustable camber like satv does. The satv arms are about 150 bucks a set cheaper too.
Reactions: pct and BWAF
pct
pct
Lost in the hills
790
1,023
Letart WV
I went with the super avt ones and added 1" spacers over the winter but I never had any problems without the spacers just wanted a little more ground clearance
Sckottty
Sckottty
35
Abilene TX
Wonder what the benefits of 30" tires. I just installed 28" and I can tell a difference in HI, with the 28", dealer recommends blower under seat to help push/pull the heat. larger tires definitely puts a lot of pressure on trans. Funny, everyone says bigger tires doesn't effect trans that much only if you play on level ground, crawling you will defiantly feel a difference in loss of torque and increase in heat from under seat. Under seat fan is one of my next projects
Reactions: BWAF
MississippiSteven
MississippiSteven
6
Mississippi
I went with the lightest most aggressive tire I could find in the interco interforce. 33lb front and 41 lbs rear. 30” pics to come.
Reactions: Smileyweb78
MississippiSteven
MississippiSteven
6
Mississippi
B89D10FE A578 4B85 9BD2 9C3B7FED519A A9D9E5BF B6B1 4C39 B740 BBE2184E1F9C 85D2EE09 29BE 4EEA 878B D6837FB559FA
Finished my build. Went with High Lifter clearance arms front and rear and 2.5” lift. 30x8x14 front interforce and 30x10x14 rear. Looks great and can’t wait to ride.
E
elkguide
3,377
7,964
Vermont
