I want to run 30” interco interforce tires on my 2016 Pioneer 1K-5. What do I need to add so I can run these tires without rubbing.
Any problem with stock axles binding with lift and high clearance a-armsOn mine anytime I change tire size I do a clutch reset
Nope..arms dont add any lift. Just arch and forward a rear movement.Any problem with stock axles binding with lift and high clearance a-arms
So no lift? Just the front and rear clearance armsNope..arms dont add any lift. Just arch and forward a rear movement.
The SATV arms dont add lift. They move the front hubs forward 1.5 in. And the rear 1.5 in back. You may need the lift to clear them if they are true 30 in tires.So no lift? Just the front and rear clearance arms
I was looking to order the high lifter armsThe SATV arms dont add lift. They move the front hubs forward 1.5 in. And the rear 1.5 in back. You may need the lift to clear them if they are true 30 in tires.
I’m running just the front forward plus liftSo no lift? Just the front and rear clearance arms
Ahh..ok. i think their arms move the hub forward on the front not sure about the rears. The forward and rear movement of the hubs is where you get your tire clearance. I do know the HL dont have the adjustable camber like satv does. The satv arms are about 150 bucks a set cheaper too.I was looking to order the high lifter arms
I went with the lightest most aggressive tire I could find in the interco interforce. 33lb front and 41 lbs rear. 30” pics to come.Wonder what the benefits of 30" tires. I just installed 28" and I can tell a difference in HI, with the 28", dealer recommends blower under seat to help push/pull the heat. larger tires definitely puts a lot of pressure on trans. Funny, everyone says bigger tires doesn't effect trans that much only if you play on level ground, crawling you will defiantly feel a difference in loss of torque and increase in heat from under seat. Under seat fan is one of my next projects
View attachment 70718 View attachment 70719 View attachment 70720
Finished my build. Went with High Lifter clearance arms front and rear and 2.5” lift. 30x8x14 front interforce and 30x10x14 rear. Looks great and can’t wait to ride.
