Just wanted a little extra room up front, I am running 5/2 offset with rear spacers so I can rotate all tires.Curious why you did the forward A arms when 32s clear stock. Unless you went crazy on the offset?
With 10” wide Terrabites the front is 66”, so about 2” wider then stock setup.Gotcha, I'd like to do 5+2 Beadlocks eventually. I was a little worried about the extra scrub causing the front to rub. How much wider do you think it is than stock in the front?
Perfect, that's basically what I would like to do.
You used 1" spacers in the rear?
I used 1-1/2” spacers for the rear, I bought the dragonfire racing ones as they looked the nicest and are black so not as noticeable.
Yes the rear is wider now also, looks to be right about 68”Gotcha, so is the rear wider now?
Yes takes some more room to turn. At first I used the steering stops from the kit but ended up removing them to reduce the radius and no rubbing so all is good.Contemplating getting these for mx X4. Do you notice much change in the turning radius?
Steering is fine off road or in sand/dirt, on pavement or hard surfaces it’s defiantly slower. Did you use the steering stops?
For the brake lines, if you flip the mounts they will give you some slack and make the lines fit easier. I’ll get you some pics of how I did mine.
Thank. Looks the same as mine. Gets really tight at full turn. I’ll have to do something to adjust.I wouldn’t use the steering stops unless it’s rubbing. I asked SuperUTV if I should use them and they said I should be fine with 32” tires and I don’t have any rubbing. Here is some pics of the drivers side brake lines and how they are routed and mounted with the stock mounts.
Did you have to drill to install your Rockbloks nice Talon by the way.
