P1000 4-5 month old 2018 P1K over heating
SuperDutyJohn
SuperDutyJohn
254
437
Vero Beach, FL
Ok, I was riding with people at night and most of the riding was slow to no movement for hours, left it on in neutral or park, the only reason I left it on was: it was 58 degrees and we kind of used the engine for heat. I made sure we moved every now and again and the fan ran, it was as warm as toast.
Next day I washed it and ran it down the road for about a 10 minute ride and there was antifreeze pouring out on the drivers side as someone noted next to me. I ran home and checked the overflow tank, it was empty and the machine never showed overheating or, the dash showing overheating. The so called temp gauge showed 2 bars. I filled it again and saw water running down the side of the radiator, then, the thing started "steaming" like crazy! I shut it off and the radiator was low, I filled the overflow tank and it was empty and kind of burped when opening the radiator cap. Then I filled the radiator with distilled water and it was lowering to the upper elbow on the drivers side after a few minutes. The fan worked one time and then it heated up with steam, the fan didn't go on? Bad radiator or do I need to do the burp procedure (need to be educated about burping) to stop this? I bought this machine in August new and did run a long time parked at idle and sporadic raising the RPM's to not idle so long. Total idle time might have been over a half hour.
Any thoughts?
Reactions: sharp
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
If the overflow box was low from the dealership and using it during the summer (Aug temps) you may have cycled it a few times and pulled in some air. Here is a car burp video and is a pretty easy procedure,
SuperDutyJohn
SuperDutyJohn
254
437
Vero Beach, FL
It worked! Thanks, I had a feeling it was the burp!
Reactions: alloutdoors
alloutdoors
alloutdoors
1,022
2,184
US
I'll have a beer on job well done for both of us :)
Reactions: SuperDutyJohn
