Well thank you but I was hoping onto let to many pics out till it was were it's supposed to be in the woods with the upper fixtures back on but...all 8 mounts had to be moved forward. The back one the least and the front 4 a lot. Didn't actually measure used masking tape to get placements but that's it. Was worried the backup lights mounted flush into the roof wouldn't fit but they still did. There were no problemsThere's the money shot. That looks amazing. Can you share exactly what mods had to be done to get the roof back on?
I totally agree!If only they came from the factory like this. All UTV's could use a chop on the factory cage in most cases
Thanks Plummer! I really appreciate it. I hope nothing happens to this one.Absolutely love it!
While running it may. I've got to button up a bunch now but know soon. It'll work for start I'm sure but now ones tried it on accessory. Fingers crossed! I won't learn new things if I don't at least try.I won't this to work. I thought capacitors were only for single instant power supply (one and done). If this can run my winch for 5 minutes. I'm doing it to.
You da man!
You do bring up some valid points. For us i definitely will stay dual batteries so we never kill factory battery and totally stay off of factory wires. There are lots of different opinions in setups but I feel very strongly about separation. For one if there is ever a chance something is wrong with the Honda electronics we cannot be held liable and second I like to be able to shut off all power at once to everything except Honda. With that being said I wouldn't be opposed to doing a big battery under the seat in addition to factory except I personally like having everything at my fingertips under the hood. Now we can't do one under the seat because of bass. I still believe in dual for many reasons and especially for others putting a big system in imo its safer. If anything went wrong your Honda won't have anything fried. We have had juice well under 10 volts and the factory Honda knows nothing of the sort still fires up like in the showroom. You can sit listening to the stereo or using lights without the rig running putting hours onto it.If wanting to keep the accessory wiring the same is the only reason, you could use remote terminals. Just install large battery under the seat and run a pair of cables salvaged from a set of #2 jumper cables. The wires would be a joined pair and then slip them in a wire loom. Install the remote terminals in the oem battery location so no working has to change.
I know you CP already know this but not every reader may have thought about it.
Also, the safe thing to do is to install a breaker or fuse on the battery!
I still haven't made up my mind on what I want to do. Right now I'm leaning toward the single battery under the seat.
Good morning if I cut 3 inches out of the A and C pillar how much do I need to cut out of the B pillar?Where it's placed is straight. After that the roof curves in towards the front and it would be more difficult as you are altering another angle.
Sent from iPhone
It would have to be close to the same amountGood morning if I cut 3 inches out of the A and C pillar how much do I need to cut out of the B pillar?
