Ensure the spring is in, thinking mine was about halfway of threaded rod. Also make sure the wire for the 4wd indicator light is intact, did you pull the connector off, or did you unscrew the nut when you took it off? The online video shows turning the nut which is not recommended IMO. It pulls off more easily.
