500/520 question
Bisley
Bisley
154
737
West Covina, CA
I had the same concerns before I bought mine. Luckily I have a 2000 ES Rancher to kind of gauge the 5 speed transmission by. There is ZERO concerns about it being low enough. It is so low that even in auto shift it only starts off in 2nd gear, not 1st.
I will clarify though that mine is running bone stock tires and rims, and this almost all desert sand and rock. I have absolutely no idea how it is with aftermarket tires and rims. Also I have no idea about the sticky mud, nor will I pretend to.
crewcabrob
crewcabrob
1,029
4,038
Omaha
Even with a jump in tire size from 24" to 27", I find 1st gear too low for anything other than what the group has said: climbing hills or heavy loads...
Dave75
Dave75
123
500
Use p5 are hard to find and when you do they are almost the price of a new one. Hopefully Honda can start making more. If you can test drive one and see if it’s right for you.
Reactions: Bmurray
34,173
I’ve never been in one of these machines but they have my interest right now. My only question for you p5 owners, do you miss not have a low range? Are gears 1&2 low enough not to need it? Thanks for your replies.
Low (1st gear) is so low I don’t even use it, starting off in second regularly, unless climbing steep…..
Reactions: Bmurray
