0860silverado
My P-1K-3's latest problem is with my rear diff. While working on a dirt road my co-worker and I came across a muddy stretch. I decided to switch from turf mode to 2WD. Diff locked up as it should but when we got back on dry dirt, it refused to unlock when I switched back to turf mode. Dash indicator showed diff unlocked but it clearly wasn't. I did the veer left/right/reverse dance to no avail. But we had work to do so off we rode with the diff locked. Then a few miles later while at 50 MPH... "BANG!!!" It broke loose. I stopped to see if the diff case broke or if fluids were leaking out anywhere. All looked ok. Then I wanted to see if maybe the diff commited suicide and sheared it's teeth so I put it 2WD again to test locking mechanism. Diff locked as it should. Switched back to turf mode and diff stayed locked until we got up to 50 MPH and then same thing happened again... "BANG!!!" My buddy and I looked at each other, furiously chuckling and shaking our heads. I wouldn't dare ever consider using 4WD after reading other posts about what happens! Well I've come to the harsh realization that my machine is basically a 66 MPH golf cart with a 7 hour driving range. It does go fast...I'll give it that. Luckily for me, the main purpose I bought it for is basically doing what a golf cart could do but faster and with a longer range between refueling (with a 5 gallon Jerry can of gasoline in the bed). I just wish it would be a machine that would serve more than that one purpose. I just feel sorry for people like farmers and such that need it to work reliably off road.
