P1000 66 MPH Golf Cart
Jshell3
I've noticed that my dash light indicator and what's - for real - happening in the transfer case don't always jive. I've probably got a cable out of adj.
But oddly, when I wiggle the forward neutral reverse lever (it's got right/left slop - spring like tension) it seems to instantly jump to my intended Turf/2wd/4wd setting.
Sorry if that doesn't make sense.
Tl.DR Try moving the "other" lever side to side while in "High range" or "Reverse" and see if that doesn't fix your getting in and out of turf mode problem @0860silverado
tundraman
tundraman
141
175
I suppose this is the reason Honda came out with I drive because they couldn't get the manual shifter to work right. Time to trade your 1000's in on the LE models.
322,776
Rear diff lock will be the same. There aren't many problems with shifting from 4wd-4wd loc unless just adjustment, that can be on the fly.
0860silverado
959
1,848
louisiana
Hey thanks man! I'll try that!
Reactions: Jshell3
TAW
TAW
73
88
Texas
Had mine up to100 mph in turf mode and still had throttle so it's actually a really fast golf cart!!! LOL!
matt33
15
35
NE PA
Are they in kph I thought mine says mph
The speedometer reads in MPH, but the Pioneer 1000 won't go anywhere near 100 MPH. With stock tires, mine will go in the mid 60's.
Reactions: JTW
TAW
TAW
73
88
Texas
Checked it is mph unless my speedometer is that far off that's what it said I was on a long asphalt road maybe Honda messed up and didn't govern mine down
Reactions: 0860silverado
0860silverado
959
1,848
louisiana
Or maybe Honda messed up and dropped a CBR1000RR engine in your Pioneer. Mistakes do happen.
