P700 700 dual battery
P
Paulgrn68
19
11
Arkansas
anyone have pictures of dual battery setup on the pioneer 700 or 700-4?
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
I haven't done this modification but...
A few years ago this was a hot topic. There were several threads with detailed information on how to set it up.
Do a search in the 700 forums. Type in "dual battery" and you should find them pretty easy. Good luck.
P
Paulgrn68
19
11
Arkansas
Thanks
Sheepdog
Sheepdog
67
70
Lyles Tennessee
Reactions: Paulgrn68
Sheepdog
Sheepdog
67
70
Lyles Tennessee
I used 4ga wire that I bought from local auto parts store. bought 10ft of it. Used the 4ga from main battery to the isolator then from the isolator up to my secondary battery. Also used the 4ga for my secondary battery ground.
98F57387 A702 4F95 835C 79F3C204DEED FDFB8D4B A6B3 4284 9BB3 D352C72E5EDA
Whistled03
Whistled03
36
32
Canton, GA
So I am only getting 8v on my second battery. It’s an Optima and it’s only about 8 months old. Any suggestions?
ByronM
ByronM
174
349
St Charles, Il
I am assuming that the main battery shows around 12.7 volts.
Where are you measuring voltage, maybe disconnect it, charge it and then check the voltage, could be a bad battery.
If the battery checks out it must not be getting a charge from the system, is there a battery isolator installed, maybe it failed.
Reactions: Whistled03
Sheepdog
Sheepdog
67
70
Lyles Tennessee
Are you checking voltage with a meter at the optima battery post. If so what’s the voltage? Also what other kind of set up do you have? Is this your main battery and or only battery? Also what are you running off the battery
Sheepdog
Sheepdog
67
70
Lyles Tennessee
O
ok reread your post so this is your secondary battery. What other parts are you running in this setup
jwfirebird
jwfirebird
927
1,446
western ny
some can be saved by using a dumb charger for a while, they have to be charged a lot,if you are using more than the rectifier puts out regardless of how many batteries you are going to deplete it and that ruins the battery. the battery isn't a power source they only store what the rectifier puts out. you can get by a little when plowing or winching but you have to charge it every time with a house charger.
the optima I have bought four recently and two lasted 2 years and the others 3-4, and that was taking care of it right not discharging it to much any of that
