Well I've held in place and had son turn wheel. I guess I'll mount where supposed to and drive her. If it's rubbing it will mark up the rim. Then will grindToo long? Concerned they might rub before you mount?
Hold them in place. Get someone to jump around in the cab. If the rubber meets the metal, grind 'em off a bit.
Good point thanksTurn far right/left. Then have someone with some WEIGHT bounce. You should find out for sure, then.
My A Arm Guards need holes like that. They were caked w mud. A water hose was no match. I have to dig it out manually.View attachment 42589 View attachment 42590 View attachment 42591 View attachment 42592 Found these on eBay for $130 with free shipping (to Alaska) and have to say I'm impressed with the quality, fit and finish. Highly recommend them!
I bought a set and received them but no install instructions... I'm hoping it will be obvious which one goes where.
They're pretty straight forward. The ones with the slots go to the rear facing rearward. You have to drill 1/4" holes in the A-arm braces (3 each up front, 1 each for rears). Be careful with tightening the fronts by the wheels. If you 'over tighten them, they'll flex the 'wings' by the wheels causing them to rub a little on the inside of 12" rims on hard right or left turns.
I also found out you must remove the rubber brake boot which I'm going to try to avoid.Thank you! Appreciate your follow up.
I was a little taken back that you must drill into the arm. Figured it might diminish the integrity.... but I guess not.
Thanks again!
They wanted over $80 to ship to Alaska. Called and asked if they could use a flat rate box that I know is big enough and cost $18, responded that they could do $66 through usps? Went to SSS offroad online $85 to ship and little higher price but UHMW vs aluminum so much better product in my opinion, Called SSS asked about flat rate box, they said they could do it and charged me $15 for shipping. Should be here next week hopefully.buy EMP no drilling the A-arms.Easy on and off.Easy to keep cleaned out
