P1000 A little help with wheel offset from WOTF
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
47mm is probably getting closer to 1+6 or 6+1 depending on the direction as they probably just round up since it's greater than 5". I'm sure that at some point a higher positive offset (30mm) is considered 5+2 vs 4+3. Using a 1" scale to describe UTV offset is a pretty coarse scale. Truck and car wheel offsets are all typically measured in mm.
105,454
Oh hell man! Now hes gonna go run in a fox hole and never come out ! 😂
1680663947112
JenElio
JenElio
64,373
603,797
Loxahatchee, florida
I'm no expert but.....47mm??
And just my 2 cents.....
Unless you're the type to rock crawl or do aggressive riding with real low PSI I don't see the need for a true bead lock really 🤷‍♂️ if you really like your wheel choice I wouldn't go crazy over a different choice just cause it's a bead lock wheel. Also just a FIY....not all tires work well with bead lock wheels.....just something to consider as well when purchasing
My mistake @Scoop I misread the diagrams posted by @Wisco-Tango
This should be a little more clear, yes.....you want the 10mm off set, that's close to a 5+2.......🤔 I think?? 😂
Screenshot 20230404 2305512
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
I was just going off the chart that was posted.....47mm ~ 5+2 offset.
I'm sure there's some wiggle room in there being that every (7" wide) wheel sold isn't really an exact 7" wide....or any other size for that matter. So the "5+2" offset is more of an approximate guid 🤷‍♂️
The good ol'......close enough!!! method
All this is a big close enough, as the 7" is probably an approximation too.
Nope. The point I was making is that +10mm is almost a perfect 4+3. vs the 5+2 that the RB3 chart calls them.
I think the real question is what size and offset are the OEM wheels. That would make this whole offset conversation a lot easier to figure out.
JenElio
JenElio
64,373
603,797
Oh gotcha.... I'm a slow learner 😂
I think most people say the P1K stock offsets are 6+1 fronts and 4+3 rears....
  • Haha
Reactions: TripleB and Scoop
208,013
I would say that all really depends on terrain and riding habits. I've ran my tires (29") as low as 7 or 8 PSI riding in TN.....(RRB, TACKETT, ETC) and haven't had any issues with a tire popping off the bead🤞🙏. I usually run around 10 to 12 PSI but I've noticed them down in the 7 and 8 range from time to time.......my buddy runs bead locks (mainly just for the looks 🙄) and we ride pretty much all the same stuff without issues. Like I said, if YOU ride trails where you see the advantage and need for a bead lock then definitely get them, or if you just really like the looks and or just want to be able to say "yeah, them are are bead locks" 😂......if not, then 99% sure you'll be fine with either of your top 2 picks
Again, just my 2 worn down cents....
I have the one sided bead locks, so if I busted a tire I can break it down trail side and stick a tube in the tire. I don't carry a spare.
Reactions: Scoop and JenElio
208,013
When I bought my wheels from Race Line, they sent me 6+1 for the front and 5+2 for the rear and they are the same stock width as OEM front and rear.
Scoop
Scoop
4,218
15,779
  3. Talon R LV
Sure looks like the wheels in question are 4+3, so I'm not sure exactly what size spacers to order for front & rear.
@Remington said "go with 5+2 and yes the wide track bundle", but ... I can't go with 5+2.
I don't want to order these wheels and have them not fit (regardless of spacers used). That would be an expensive mistake.
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
This makes sense assuming the track is even front to rear from the factory. Having to add a 1" spacer to the rear if using a 5+2 setup all around would keep the same front to rear track. It would just widden the overall machine by 2".
208,013
You got it!
208,013
Ow my, the info is for a P1?
Kinlaw
Kinlaw
220
1,143
NC
Those wheels will look awesome on your machine, Scoop.
Scoop
Scoop
4,218
15,779
  3. Talon R LV
Welp, I'm gonna steer clear of 4+3 wheels, so the Fuels (above) are both out.
I've, again, narrowed it down to the following two 15x7 5+2 in bronze.
It's a beadlock vs a non-beadlock for the exact same price: Tusk Uinta beadlock vs Raceline Krank.
16808346537491680834663599
Reactions: WagginTail
