P1000 A little help with wheel offset from WOTF
208,013
Welp, I'm gonna steer clear of 4+3 wheels, so the Fuels (above) are both out.
I've, again, narrowed it down to the following two 15x7 5+2 in bronze.
It's a beadlock vs a non-beadlock for the exact same price: Tusk Uinta beadlock vs Raceline Krank.
View attachment 382389View attachment 382390
Pick the one that's easiest to clean! Left!
  • Haha
Reactions: Remington and Scoop
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
I had bad luck with 5+2 raceline beadlocks. The 5+2 Racelines had a 30mm offset as I recall and they stuck outside the OEM brake caliper shields. I broke 2 wheels one day when rocks got stuck on the calipers. Ended up needing 2 wheels, 2 calipers, 2 caliper brackets, 2 hubs, and 2 rotors. Since switching to non bead lock wheels I've only popped a bead once and the tires have never leaked like the beadlocks always did.
Scoop
Scoop
4,239
15,789
  3. Talon R LV
Thanks for the 411.
Those Raceline A94 Kranks are non- beadlock wheels and are listed as 5+2 +10mm. Thoughts?
Reactions: WagginTail
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
Thanks for the 411.
5+2 +10mm is what I run now. They don't look as good but I haven't had any issues
Reactions: Scoop
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
5+2 +10mm is likely a 4+3 wheel regardless on how manufacturers label them. It is either a 5+2 or +10mm offset, it can't be both as the math doesn't work. 7" wide (178mm) = 99mm (3.9") x 79mm (3.1").
@Scoop If something is listed both ways, I'd ask them to verify if it is one or the other before buying them.
Scoop
Scoop
4,239
15,789
  3. Talon R LV
Solid. Much appreciated. ²
I agree, and that's what confuses me. I've seen the same wheel listed on the same website with one description saying "5+2 +10mm" and right below it, the same wheel listed identically but "5+2 +38mm". I'm like ... WTF?!
Scoop
Scoop
4,239
15,789
  3. Talon R LV
Well, we can let this thread simmer down to a slow boil. Just placed my order for five each of the following:
Tusk Uinta Beadlock Wheel 4/137 15x7 5.0 + 2.0 Bronze
Tusk Aramid Terrabite 10 Ply Tire 30x10-15
Plus Tusk tapered chrome spline lugs (21), a spline lug nut key and a nice Tusk Extendable UTV Lug Wrench Kit to throw in the trail bag.
They said they would assemble and ship today. Guess I better get working on that a-arm tab reinforcement project and installing the SuperATV a-arms.
Thanks for yet again, helping me spend more $$$ ... 😄
Screenshot 20230407 130138 DuckDuckGoScreenshot 20230407 130210 DuckDuckGo
13,373
65,209
I run 4+3 on my machine. Only spacers on the rear. Either 1.25 or 1.5" I honestly don't recall.
Reactions: Smitty335 and Scoop
