What are y’all using? The ones I ordered from Amazon were supposed to mount between the ROPS, but do not fit.
What kind of bolts are u using?the brackets on my lights are hard to tighten with the satv flip up windshield,
I didn’t think about changing the bolts out, that may be my best bet, this is the style brackets that my lights came withWhat kind of bolts are u using?
I when to the hardware and got hexed head bolts. You can get an Allen wrench in there much easier that an wrench or socket. I have the SATV flip as well. If u have any pics of your bracket set up, that would help.
yep! I had the same brackets. With the washers, to level the bracket out will give u the right length bolt u need.I didn’t think about changing the bolts out, that may be my best bet
You talking about the side bolts that go into the actual light are hard to tighten up? I have the same mounts you have with satv flip up windshield alsoI tried the bolts on the hood but the brackets on my lights are hard to tighten with the satv flip up windshield, anyone try anything else, or know how to contact the guy on Facebook? Rough country doesn’t sell the brackets alone…..
Yes there isn’t enough clearance to get a wrench on the boltsYou talking about the side bolts that go into the actual light are hard to tighten up? I have the same mounts you have with satv flip up windshield also
If I'm remembering right I tightened the big bolt that goes through the mount and the fender. Turned the light to tighten the side bolts then turned the light the way I wanted it 🤷♂️Yes there isn’t enough clearance to get a wrench on the bolts
Did you have to modify them ( drill new holes)?I put a front rack on the front of my rig and tried different mounts for the lights, but most of them I didn't care for. I finally mounted these on the lower section of the windshield that are made for a jeep and like how they raise the lights up higher. I can try to get some pics tomorrow but here they are from Amazon.
