P1000 About to upgrade
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
After 2 years with the P5, I sold it Friday. Great machines for what they are, but I need something a little bigger and more capable. I was almost sold on a Wolverine, but after driving different machines at 2 dealerships today, I think I'm gonna go with a P1000. Now I just have to decide 3 or 5 seater. Only a $500 difference between the base model with EPS on the 3 or 5 seater, so probably go with the 5.
Plan on taking a day off this week and going to pick one out.
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
You can use 5 like a 3 but you'll always have room for 5
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
Almost certain I'll go with the 1k-5. I guess I need to decide on the base model with EPS or Deluxe. Only about $900 difference there.
E
elkguide
3,377
7,964
Vermont
Power steering is the only must have. The rest is totally up to you and how you are going to use it.
We need pictures!
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
We need pictures!
I'll definatly add pics as soon as I get her home. And I'll never buy another machine without power steering!
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I think the deluxe model should be the base model and Honda should offer Fox Shocks with and without the LE i4x4. The colored panels, power steering and paddle shifters are must have options
Reactions: Cuoutdoors
208,729
Sold it Friday
You are between a rock and a hard place! I have never owned a 500 but I really like them, size wise. Think you will like a P 1000, the width will take a little getting used to. If you ever do tires and wheels, you can order different wheel off sets front and rear to retain stock width and not run spacers.
Reactions: Bad_bowtie
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
Wanting to add a winch, front light bar, and rear cubes. Would I need to do a 2nd battery and or fuse block? I am an absolute novice at electrical. If someone could post a parts list of must haves, I will go ahead and start ordering parts.
208,729
Good frickion luck, no there are a bunch threads here that will help you with pictures, just stay away from @drfuba posts.:p He's really into whips! :eek:
The second battery isn’t necessarily a must but it is cheap insurance! I would do it again particularly if you think you’ll winch much! I’ll get on amazon when I get home and get you a parts list. What size light bar do you want? If you’re not going huge then you can get by with a fuse block instead of a relayed box.
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
Thank Josh, I appreciate it. Not sure what size exactly, probably one across the bottom of windshield like several here have.
I've been reading for the last two days about wiring, I think I've confused myself more than anything. Not that that's a hard thing to do.
Reactions: JTW
Lol.. that’s what I have and it’s ok. I’ll go into more detail when I’m not driving
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Heres everything i just ordered to do mine. Been running a single batt. Setup for over 2 years...its finally time for.me ro do it.
True UTV-SBI-CM UTV Dual Battery... https://www.amazon.com/dp/B00WRJI3BU?tag=sxsweb24-20
Mighty Max Battery 12V 26AH Battery... https://www.amazon.com/dp/B01N0P2O2O?tag=sxsweb24-20
Blue Sea Systems ST Blade Fuse Block... https://www.amazon.com/dp/B001P6FTHC?tag=sxsweb24-20
Stinger SGP38 80-AMP Battery Isolator... https://www.amazon.com/dp/B001HC6UJ0?tag=sxsweb24-20
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
About time!
@Bad_bowtie this is everything minus a 4gage set of jumper cables and and ends. Also, the only thing you may choose to do instead is a waterproof relayed fuse box,
https://www.amazon.com/Concours-Spe...proof-Bussmann/dp/B01FWILL20/?tag=sxsweb24-20
considering you’re thinking about running a big light bar. I wouldn’t use relays if I didn’t have to on a high amp draw like a 52” 300 watt light bar. Check out @joeymt33 build thread and how he swapped out to smaller better cube lights from the light bar. Go that route and you don’t need the relays. For a switch panel @mystic1219 makes custom panels that are awesome. And you can use cheap switches from amazon OR I would have used otrattw switches if I were doing it again.
This might help you a little... also, @CumminsPusher sent me a pic of a wiring digram that helped a lot. But I can’t don’t the pic now.
E2686959 6884 447C 9B32 EC486AE5592D AC876E87 AED8 4AAE B2D1 755D10D1540D 90D71782 DF17 45BE 89F5 4EA8DAE70847 FBE9D739 2DB5 4DF1 8A80 B724AF25657D 5988A6F3 C14D 4BC5 B6A4 9815AC006316 119F8FDC AB33 4AE3 93FB B666E10FC22B B638F4C4 66A2 4B1C 9B13 69790B6DDA48
