G
I'm adding a dual battery with True isolator and Blue Sea Systems fuse block to my 1000 to handle accessories. Power for the accessory block wiill come from the Odyssey brand 2nd battery. But if I want switched power for an accessory, how does that work? Is there a way to make some of the pickups on the accessory block siwtched?
Also - can I simply run a battery cable back to the main battery negative terminal to 'pick up' the system ground? Or just run a cable to a drilled/tapped hole in the frame under the hood?
Any help for this electrically challenged builder will be appreciated. (But pretend you're explaining things to your Golden Retriever in any reply! ) Fuse block link below:
https://www.amazon.com/gp/product/B000THQ0CQ/?tag=sxsweb24-20
